03 GT 5speed swap
100GT03
9
I have a 03GT with an auto and have a wrecked 01 bullitt i am able to get parts off of and wanting to do a 5 speed swap what all is intitled to doing this swap? and if i take the computer out of the bullitt and put it in my car will it just work or is there anything i need to make it work after changing it over? thanks for any help....
While you are at it take off the intake assembly off the bullitt. But for the trans you will need the pedal assembly the trans with bell housing, new clutch kit with all new bearing, clutch fork, cable, drive shaft, shifter but im not sure about the wirin i beleive the trans and 02 sensors are on a sepperate harness then the rest of the motor and they should unplug. Somone on here has done the swap they should chime in. Good luck.
ok i have looked around and heard you can use the automatic bezel and just put the manual boot on it has anyone done this or know if it will work cause if i can i wouldn't mind just having to find a boot and get the clips for it...thanks for any help
