  • SN95 4.6L Mustang Tech
03 GT' Dipstick error? TSB?
  • Thread starter Thread starter modu1ar tek
  • Start date Start date Dec 14, 2003
M
modu1ar tek
139
  • Dec 14, 2003
When I did my oil change today, I filled up 6 qts with a new oil filter, but the oil was barely on the dipstick. Right near the MIN mark. I didn't fill up the 7th quart and did some research, and I guess there is a TSB regarding mis-marked dipsticks for Mustangs. So right now my car has 6 quarts of oil in it, but it's not at the MAX level on the dipstick. Can anyone shed some light on this? Is my cars dipstick mis-printed? What do I need to do?.....Thanks
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Dec 14, 2003
  • Dec 14, 2003
Same thing happened to me... in summer.. i put in 6 qts and it's right on the good level.. now in winter.. i put in 6 qts and it's just got some of the tips.. peharps it's the season issue?
ken44ny
86
long island,ny
Dec 14, 2003
  • Dec 14, 2003
ijust changed mine and it took 6 1/2 quarts.By the way-whats up w/ these corkscew dipsticks?-annoying
ken44ny
86
long island,ny
Dec 14, 2003
  • Dec 14, 2003
where is the TSB located at?
SilverGTV8
295
West Brookfield, MA
Dec 14, 2003
  • Dec 14, 2003
I know mach dipsitcks were miss marked. This is the first I have heard of the GT sticks being miss marked. When i changed my oil it fell right in the middle fo the min max marks both time. Only put in 6qts. Don't worry about the marks. Make a mental note of where it was so you can see if you are burning oil. If you put in to much oil it can cause a whole mess of problems. Frothing, rear main seal failure, loss of hp. 6qts is all you need.
Stang2003GT
254
  • Dec 14, 2003
I put 5 quarts and it says that im full.
351CJ
1,732
  • Dec 14, 2003
The 2001 Owner's manual says 5 quarts with filter change GT 4.6L SOHC). 5 Quarts and it's right at the full mark.
2003 should be the same do you have a GT, Mach 1 or Cobra?
M
modu1ar tek
139
  • Dec 14, 2003
It's an 03 GT. Im going to call the dealer after finals and see what's up. They will probably blame my wheels, they'll say since the car is elevated a little more, it causes the oil to seem low. Haha
WaltA
230
Dec 15, 2003
  • Dec 15, 2003
The TSB I saw, only was simplistic instructions on how to correctly read a dip-stick. It had nothing about the dip-stick being marked wrong, on either the 4.6 SOHC or the 4.6 DOHC.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
