  • 1994 - 1995 Specific Tech
03 Rotors on a SN95
  • Thread starter Thread starter Zero_chance
  • Start date Start date Dec 18, 2007
Zero_chance
1,244
Maricopa, AZ
Dec 18, 2007
  • Dec 18, 2007
Im upgrading my calipers with some dual pistons off of an 03 and the persons going to give me the rotors as well. Will they fit on a 95 or no? Im upgrading to 18 inch saleens in the spring when I do the brake upgrade so fitment inside the wheel wont be an issue. Just wondering if the mounting depth to the hub was different or anything like that. Im hoping they work because my right front rotors warped anyway...
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 18, 2007
  • Dec 18, 2007
They'll work perfectly. The hub assembly is the same from 94-04, just a different spindle for a wider track on 96-98, and then again from 99-04.
Zero_chance
1,244
Maricopa, AZ
Dec 18, 2007
  • Dec 18, 2007
Good to know. Thanks.
Kumm3
527
33
69
East Hartford, CT
Dec 18, 2007
  • Dec 18, 2007
If your doing the dual piston calipers off the 03 V6s and GTs, youll need to do some minor clearancing on the caliper mounting "knuckles" on the spindle.
Once you go to bolt them on, youll see where its needed.
Zero_chance
1,244
Maricopa, AZ
Dec 18, 2007
  • Dec 18, 2007
Is it true that on the passenger side Ill need an adapter to hook up to the stock brake fitting? Believe it was a weatherhead 7828 fitting?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 18, 2007
  • Dec 18, 2007
dont think so, never heard of that
G
gotboost562
So. CA
Feb 8, 2008
  • Feb 8, 2008
Sorry to bring up an old old thread, but i plan on doing the same thing. I have some 03 PBR calipers to go on my 95 spindles, do I need to use the 03 rotors or can I reuse my 95 rotors? Thanks.
-Mike
HGFireHazard
460
Michigan
Feb 8, 2008
  • Feb 8, 2008
You need to use the 03 rotors.
Blackened302
1,439
South TX
Feb 8, 2008
  • Feb 8, 2008
just did this today!
used the calipers and rotors off an 03 cobra, and the steel braided lines and coarse threaded banjo bolts from StangSuspension.
at first i thought i needed adapters (see this thread) but it wound up that the lines are side-specific (just as the calipers and rotors are).
N
Nagash01WS6
402
Deland, FL
Feb 9, 2008
#10
  • Feb 9, 2008
  • #10
Each side has a diff size fitting.
I got two of the same size fittings for -3AN brake lines, and I had to get an adapter for one side, I want to say it was the drivers side.
If you use a mustang specific brake line setup there should be no issues.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 9, 2008
#11
  • Feb 9, 2008
  • #11
PBR's to a FOX body....yes.
PBR's to a 94-95 maybe not...but if so..it cost me 1.37 at the auto parts store.
G
gotboost562
So. CA
Feb 9, 2008
#12
  • Feb 9, 2008
  • #12
I've heard the Fox brake lines are something like 6" longer than the SN95 ones. When using a PBR caliper on a Fox, which line is better to use? Isn't there some grinding needed to use a Fox line on an SN95 caliper?
PUNISHER RACING
1,124
FORD CITY, PA.
Feb 10, 2008
#13
  • Feb 10, 2008
  • #13
use the pbr calipers on a fox, you will need to use the pbr lines. also you can use the fox lines but there is alot of grinding to be done on them to make it work. you will need M10 to 3/16 line adapters. on the pass side you will have to cut off the existing flair and 7/16 nut and replace it with a 3/16 nut and reflare it. then just bolt it all up. i also used the 99-04 spindles and all on my project worked out great.
D
DJiCE
117
Bloomfield, NJ
Feb 10, 2008
#14
  • Feb 10, 2008
  • #14
ARE Rotors side specific??? I thought R/L where the same???
BlownFiveLiter
18
108
Chicagoland
Feb 10, 2008
#15
  • Feb 10, 2008
  • #15
Unless they're the crossdrilled or slotted rotors, they're not side specific.
Blackened302
1,439
South TX
Feb 10, 2008
#16
  • Feb 10, 2008
  • #16
^ +1
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
P
Wheels-Tires 04 Mustang Wheels won't sit against rotor
  • pindude80
  • Jun 10, 2024
  • 3 4 5
7K
Fox 5.0 Mustang Tech Apr 28, 2025
pindude80
P
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
