  • SN95 4.6L Mustang Tech
03GT CAM?
  • Thread starter Thread starter lilcgt
  • Start date Start date Apr 4, 2004
1 of 2 Next Last
L
lilcgt
  • Apr 4, 2004
I have a 03 GT 5spd 4:10 gears diablo chip cold air kit eibach springs and nitto drags, i drive the car pretty much everyday nut do have another veichle i am wanting to put a cam in it just looking for advice i am a rookie when it comes to cars.
P
Pootiestang
That's MISTER boy to you!
3,835
Sav, Ga
Apr 4, 2004
  • Apr 4, 2004
First off, you have a single overhead cam set up. Meaning two cams, one in each head. Expect to pay about 500 to 600 for a set, I think.
Subscribing.
boulderado
54
San Diego, CA
Apr 4, 2004
  • Apr 4, 2004
Im interested in this as well. Beyond the 500 to 600 bucks youll pay for the cams I have heard you will pay 5-6 hours of labor at your local shop, unless you can put them in yourselves. My questions are:
1. aftermarket cams pass emissions?
2. reliablility issues with cams?
3. horsepower gains?
4. you gain power at certain RPMs and lose it elsewhere?
5. recommended aftermarket cam set up on a stock 02/03 GT?
nickthegenius
1,631
Elwood, IN
Apr 4, 2004
  • Apr 4, 2004
To answer your questions:
1. Probably not. This has been asked on here and Modular Depot and the general consensus is "no". I even think one of the VT Engines guys chimed in on a response at Mod Depot and said the same thing.
2. No reliability issues other than if you don't change the valve springs and break one. VT Stage 1 cams don't require a spring change, but their Stage 2 cams and all the Comp Cams "recommend" new springs. This is one of those areas where it is "better safe than sorry". The 4.6L is an intereference motor and if you break a spring and the valve drops open even partially, there is a high chance of bending that valve and/or damaging the piston. A friend of mine and I changed my valve springs last week. The passenger side took about 4 hours. Then after we learned the process, the driver's side took 1.5 hours. Its not hard, its just tedious work.
3. Off the top of my head, the only ones I can think of with posted gains before/after are Mustang92's VT Stage I cams where he gained 22hp. Also, VT Engines posted a dyno graph on Modular Depot of a near stock (only mods were weld-in Flowmasters) '99-up Mustang that gained 29hp with their Stage 2 grind.
4. To a certain extent, yes. Most will gain more hp up top, but are still very streetable uless you get crazy.
5. For a daily driven car, I would suggest the VT Stage I cams or the Comp Cams XE262AH cams. If you can live with a rougher idle in your daily driver, then try the VT Stage II or Comp Cams XE270AH cams (thats what I have). Anything stouter than that, and you'll need ported heads. SHM has some good grinds, but I really don't know any of the specifics so you might want to look into them, too.
My other suggestions would be that if you are changing them yourself, allow yourself plenty of time to do the swap. It took us a whole week, but we just worked from 8 or 8:30 to 10pm each night. We had a total of about 12 hours doing the springs and cams.
maddogg545
91
NJ
Apr 4, 2004
  • Apr 4, 2004
How would you know if you actually did that kind of damage to your engine? How would it run? Would it sound any different?
nickthegenius
1,631
Elwood, IN
Apr 4, 2004
  • Apr 4, 2004
Hmm. IF you got really lucky, you might end up with a really rough running car and depending on if it was an exhaust or intake valve, it would smoke. More than likely, it would drop enough that piston/valve contact would take place and you would definitely hear it on top of the fact that the car would run poorly.
I had it happen in a small block Chrysler once. It wasn't because of the same reason (spring breaking), but mine starting running very roughly and then locked up. It happened because of "coil bind". The factory springs had shims under them and the guy that installed the aftermarket springs left them in. Then, when the valve was at full lift, the spring was fully compressed and it actually shot the valve through the keepers and into the cylinder. It scored the walls and cracked the piston.
boulderado
54
San Diego, CA
Apr 4, 2004
  • Apr 4, 2004
If they arnt emissions legal then how do the guys who have them on their cars get registered?
nickthegenius
1,631
Elwood, IN
Apr 4, 2004
  • Apr 4, 2004
We don't have testing in Indiana yet. Although I haven't heard of someone doing it for cams, some guys on here with offroad pipes have mentioned slipping the guy doing the testing a few bucks to pass them. Also, knowing someone with a shop might help.
Infinity
956
Charlestown, IN
Apr 5, 2004
  • Apr 5, 2004
There IS testing in Indiana, but only in Clark, Floyd, and one northern county (I think around South Bend). Fortunately, they're talking about doing away with the testing in Floyd/Clark altogether (sweet! I have lived in either of these counties all my life). People pass here all the time because the testing is ran by contracted individuals, and not the state. BUT, I've been pulled over and had a mirror ran under my car twice now by the DOT.
L
lilcgt
#10
  • Apr 5, 2004
  • #10
So im guessing that i should go with the VT stage 2 cams and change the springs as well here in florida they did away with emissions testing so im good onthat one
NasaGT
1,993
Virginia
Apr 5, 2004
#11
  • Apr 5, 2004
  • #11
Nickthegenius, do you have any kind of tune to go with your cams or are you running on the stock ECU???
Also, update your sig since the cams are installed!
L
lilcgt
#12
  • Apr 5, 2004
  • #12
hey nick was that best time with all the listed mods excludeing the cams????
just wondering cause my best time is 13.980@99.46
nickthegenius
1,631
Elwood, IN
Apr 5, 2004
#13
  • Apr 5, 2004
  • #13
Not yet. The car runs OK, but the idle is kind of funky and sometimes wants to stall at stop signs. There is a place about 30 minutes away that does tuning and has a great reputation and hope to go there in a week or two.
That pass was made last September and at the time the only mod was my Magnaflow catback, wheels, and some cosmetic stuff. All the mods in my sig have been added since then while the car was sitting during the winter.
hognutz
1,940
albany, oregon
Apr 5, 2004
#14
  • Apr 5, 2004
  • #14
my .02 would be comp 270's or VT wild. I would change springs even with stage 1. I don't like taking chances. springs are not $500. I don't like saving a little money when you are risking a lot of money if something happens.
I am not sure if stage II would pass emissions. I would email the cam manufacturer.
with the correct cam you should not really lose low end but you can't have a high end and low end cam. there is always a trade off. With 281ci your best bet is always going to be low gear and high end though. there is no such thing as lots of torque at 4.6l without a power adder.
I really think this is the kind of mod you should do yourself though. the labor cost is high compared to the hp gain.
If you pay someone to do this cams is going to set you back $1500 by the time it is tuned. that is starting to get $$$$.
L
lilcgt
#15
  • Apr 5, 2004
  • #15
so you would recomend this even in a daily driven car
P
Pootiestang
3,835
Sav, Ga
Apr 5, 2004
#16
  • Apr 5, 2004
  • #16
are you saying that 4.10s and cams are a good match up or that they are not?
RedBullitt
462
Morgantown WV
Oct 31, 2005
#17
  • Oct 31, 2005
  • #17
they are a good match up in most cases, vt stage 1 and 2 being one of them
A
ALEX2028
57
#18
  • Nov 1, 2005
  • #18
does anyone have a write up on the cam install. also nick mentioned that on one of his cars the springs broke because the shims were left on. does this go for the 4.6 also .
68
#19
  • Nov 1, 2005
  • #19
I'd go with stage II cams with 3.73 gears.
scalder
375
Dallas/Plano TX
Nov 1, 2005
#20
  • Nov 1, 2005
  • #20
Dunno about the 3.73's....probably wouldn't go any less than 4.10's with the Stage II cams. Plus 4.10's are fine anyway, even on your DD.
1 of 2 Next Last
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
