  • 2005 - 2009 Specific Tech
Engine 06 Gt
  • Thread starter Thread starter AmarilloStang
  • Start date Start date Feb 19, 2015
AmarilloStang
Amarillo, Texas
Feb 19, 2015
  • Feb 19, 2015
Help!! Angry Wrench problem. I cleaned Throttle Body changed TPS. Installed new plugs and idle still sticking and engine running very poorly. Acts like it's not firing on all cylinders. Noticeable horsepower loss. Could it be my Cats? When I bought the car it already had Mods: ( Not sure if there has been a tune installed or not) 20" BOSS Wheels/K&N CAI/BBK 62mm Throttle Body/X-Pipe
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Feb 20, 2015
  • Feb 20, 2015
Wondering if part of it could be the throttle body, I've heard of people having issues with them.
Reactions: racerraj
R
racerraj
493
32
39
Dickson, TN
Feb 20, 2015
  • Feb 20, 2015
Mass Air Sensor maybe? And if cats are clogged, yes. But I doubt that. The TPS you changed, was that on the pedal side?
SpartaPerformance
2,517
61
89
Long Island NY
Feb 21, 2015
  • Feb 21, 2015
You're going to be chasing your tail if its modded and you don't know if the tune is good or not. Is it possible to return to stock? Maybe get a new tune??
Dino Dino Bambino
1,673
90
79
Cyprus
Feb 22, 2015
  • Feb 22, 2015
Try scanning the ECU for codes and see what you come up with. It'll help in troubleshooting the problem.
C
cmann
38
Mar 27, 2015
  • Mar 27, 2015
Did you put any anti-seize on the new sparkplugs before you installed them?
R
racerraj
493
32
39
Dickson, TN
Apr 2, 2015
  • Apr 2, 2015
I put a tiny amount on the smooth part, but I did not put any on the threads. When I pulled the plugs at 60,000 miles to check, they looked good. I read somewhere not to put it on the threads, because it is easier to overtighten, and it not tightened enough, easy for them back out. I am sure it would be fine to put a small amount on it though.
C
cmann
38
Apr 2, 2015
  • Apr 2, 2015
As long as you did not get any anti seize on or near the tip of the plug you should be ok. It's a known issue if you get even a little anti seize on the tip, it will cause all kinds of misfire problems.
Reactions: racerraj
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
2005 - 2009 Specific Tech Sep 6, 2025
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
