06 mustang balancer
1fastz
124
For some reason my 06 mustang has NO HOLES drilled in the harmonic balancer to use a puller on it.
is this normal did ford go to a special tool for 2006 for the balancers ?
there realy is no way to pull this balancer short of drilling and taping the holes in the three arms.
however there is no way im getting in there to drill the holes without removing the radiator etc.
Nope they do not have holes for you to pull with. You will have to get a puller that has fingers that pull on the backside of the balancer. I hope that helps.
Thanks Mike
My 05 also did not have holes!
I used a standard puller with an old socket as a spacer.
It was a tight fit, but no need to remove the radiator.
Ford really blew it on this little detail.
And the balancer was nearly WELDED ON... it took a whole lot of pressure and even some heating up to get it to break free. :notnice:
GOOD LUCK!
bah none of my pullers would work im going to picjk one up tomorrow
on the plus side it dynoed 302 rwhp 321 rwtq with out the pullyes
just the cat back c and l cold air tune and the imrc elimnator plates
