06 Navigator as a parts donor
vristang
4,933
101
124
Seattle
My 2006 Lincoln Navigator may be done.
Engine needs to come out for clean-up, maybe full rebuild.
I know these engines are generally hated, and have experienced why…. But what would it actually take to swap a 3v 5.4 into a fox body, along with the 6spd automatic.
I have enjoyed the airbag suspension as well.
Has that been swapped into a fox body?
Basically, I want to consider all options at this point…
Horrible idea? If so, why?
It has been done. Those engines are pretty tall, so you will need a cowl
Basically the same concept as any 4.6L/coyote swap. You’ll need parts, and some of them aren’t cheap.
All the expense, including rebuilding the 5.4….maybe coyote might be a better choice?
Reactions: Shakerhood
Swaps soak up time and money.
Most likely when this project is done it won't have been an effective use of either, especially if it needs shortblock work.
