1.7 rr with twisted wedge heads help?
The timing at the valves changes a bit, in particular the valve lift and speed that the valves open and close.
Luckily, near or peak lift occurs when your piston is near 2 inches GOING DOWN in the piston cylinder wall:nice:
The added lift the 1.7 roller rocker gives should not affect your p-v clearance numbers in where you can't run the cam.
The best thing to do though, is check:)
Some extra information for you:nice:
TFS 1 - 221*/225* - 275*/279* - .499"/.510" - .312"/.319" - 112* - 108*/116* - 2,000-5,500 RPM
1.6 Rocker Ratio
Intake Opening: 3* BTDC
Intake Closing: 38* ABDC
Exhaust Opening: 49* BBDC
Exhaust Closing: 4* BTDC
Recommended Valve Springs:
TFS-51400413 with 1.6 ratio rocker arms
TFS-31400414 with 1.7 ratio rocker arms
