1 yr later still trying!
trelz4
38
decatur,illinois
last july i had a gt-40 crate w/ x heads, e cam, 24lbs inj., trick flow track heat intake, bbk 65mm throttle body, c&l cold air intake k&n filter. ford 9mm plug wiresfireball ignition. a buddy of mine burnt me a chip thats not in yet but my question would be, i have very poor low end power from idle to 2500rpms it misses and backfires then @ 2500 it takes off would not having the chip in have anything to do with this? i found that my aic was bad and replaced it. so sunday i will get my chip in and tps set. but any other suggestions?
Just curious of how you have the chip but it is not in...I had a SCT ship installed and dyno'd same time......with mods I don't think a pre-cut chip will get all the bugs worked out and Hp max for you....there are some guys who do some tuning on here that will have more info......
first he burnt me a pro-m chip but winter came and tuning stopped, he has a custom tune on a SCT chip but we havnt put it in yet, then we will hook up the wide band but i dont know much about tuning so im going by what he is telling me. how do i get ahold of these guys that your talking about for tuning? i was wondering if tourqe converter and tranny has some effect on this. just want it to run like you guys cars, in need of help in decatur,il
Don 95Vert is the one who tuned my car....Lasotaracing.com......I know that he makes SCT chips that upgrade a stock motor and will mail them out but when you have a custom set up...(H/C/I etc) you will need that tune for your specific set up or your not getting your moneys worth....as far as the stall goes.....My gears threw off my shift points and Don set that up through the chip....I have the 2300 stall in now and it is way low for what I have....I don't know if it effects turning because when I talked to Don and his son about ordering the 3500 stall they said it won't affect my tune.....just my low end and launch......hopefully I helped...lol
trelz4 said:
thak you. ill get my chip in and tps set and then work from there ill keep you posted if your interested. hopefully in 2 to 3 months i have my C4 and 3500 stall. thanks again and ill keep checking in :)
:nice: keep us updated
I'll bet almost anything this is the tune. The only way I could get my car to even run when I changed H/C/I injectors, and MAF was with a good tuner shop. Forget about just slapping on a MAF from somehwere "programmed" for your size injectors. I DIDN'T work for me. Mail order chip did not work either. TAKE it to a shop even if you have to tow it like I did and then drive it out. Good luck.
just touching base come to find out my maf was wrong it was for 24s but 86-93 comp. so i got it replaced and different plugs, the wideband is in the car but we havent took it for a ride yet should be tonight so keep my fingers crossed that its done soon :)
