10 holes aka phone dials.......
they changed the inside diameter of the wheels to clear the larger 87 brakes. this is from all my experience on foureyedpride.....
having said that, either ten hole will still clear.
a 15" is not a 15"
I have an 86 ssp and I upgraded to 87+ front brakes...after I did that, the 15x7 85/86 specific ssp wheels would no longer clear the newer brakes :( on went ten holes.
I have an 86 Capri with the 5.0L/AOD....I swapped out the spindles, put in 11" rotors and the Lincoln Continental over-sized calipers with the SVO master cylinder and Wilwood 10psi residual valve for the stock drums. I kept my 10 holes and they fit fine. A buddy sold me two more 10 holes to swap out my two wheels that had peeling clear coat and curb rash......point is, even with the larger calipers, all six wheels ended up fitting just fine.
