- Jul 11, 2010
- 1,135
- 64
- 69
4.6 PI 2V Windsor heads with cams and valve covers (13/14 Bolt)
4.6 Aluminum Block (bare)
44 LB Bosch Injectors
Moroso 7 qt oil pan (4.6/5.4)
4.6 4V B-Style Heads with cams and valve covers (from 96 Mark VIII)
96 Mark VIII Intake Manifold with TB and IMRC's
4.6 cast iron crankshaft with 6 bolt flex plate
19lb injectors (set of 8)
96-98 NPI ECU
99-04 PI ECU
99-04 Vortech Mounting Bracket
Vortech Power Cooler Reservoir (Reservoir ONLY)
2 Cobra Fuel Pumps (03-04)
96-98 Cobra MAF sensor for 24 lbers
4.6 auto transmission
3.27 gears for 8.8
Aftermarket gauge cluster bezel (holds 2 extra gauges)
Temp gauge, Boost gauge, A/F Ratio gauge (Not a wide-band)
Plus extra stuff...351 block and crank, 5.0 8 bolt flex plate, 4.6 4V alternator, modular water pump, modular 4.6 radiator, modular oil pump, extra harmonic balancer, extra pulleys, 4V coolant crossover, 4.6 timing covers (I have 2), 4V exhaust manifold gaskets (new in package), 2 wiring harnesses (2V - both sets will make 1 good set), SOHC fuel rail...take whatever you want or leave whatever you don't want, it's up to you...use whatever you need and sell the rest if you want. I just gotta get this stuff outta here...
I will lower the price if you don't want certain items or if you wanna mix and match so shoot me some offers. I would like to clean house so everything is up for grabs...
If the price seems high for this stuff then just tell me what you think a reasonable offer would be and we can go from there. Thanks...
96-98 NPI ECU
99-04 PI ECU
3.27 gears for 8.8
