12.9 with 347
  • Thread starter Thread starter blue87lx
  • Start date Start date Oct 29, 2006
blue87lx
175
  • Oct 29, 2006
r/t- .326
60' -1.814
1/8 -8.301
mph -83.90
1000 -10.819
1/4 -12.942
mph -106.47
my other runs were all 13.0-13.4 range with all 106mph+/- tenths
i got a 347 street fighter kit from chp 9.5 to 1 compression.
edelbrock performer heads, trick flow track heat upper and lower, 24lb injectors, msd 6al, pro billet distributer and coil, trick flow cam(.542 .563)
roller rockers, tremec trans, aluminum driveshaft, shorty headers, 2 1/2 off road mac hpipe with flowmasters dumper, 4.10 posi rear, lakewood upper and lower control arms, 255lph pump, custom computer, welds all the way around with et streets in the rear at 9psi. launching it at 3000. how can i get better time?
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Oct 29, 2006
  • Oct 29, 2006
put the tires at about 11 psi, launch at 4k rpm, and powershift, where are you shifting at? No offense but those times are horrible.
Modular2v
3,222
23
99
oklahoma
Oct 29, 2006
  • Oct 29, 2006
yeah, that is a pretty bad time!!!!! you could have thrown a set of gt40p heads on and gotten better than that!
blue66tang
1,092
Medford, OR
Oct 29, 2006
  • Oct 29, 2006
Kinda what i was thinking.
nitrous_bob
45
st clair shores MI
Oct 30, 2006
  • Oct 30, 2006
the mph is good for 12.60-12.50's
the 60' isn't bad, you could knock about 2 tenths of fit, at least 1 tenth. i'm thinking get in the 1.68-1.72 range and you'll see 12.60-12.70
cheap way to hook a little better is an air bag in the right coil, use 8 psi in it, $30 and about an hour of your time.
what lca's ?
shift rpm ? are you shifting off the stock tach?
at least use a light, try a 5200 chip, then 5400, then maybe even 5600 but wherever your mph is best use that chip as your shift point, remember when the light comes on, it will take about 300 more rpm for you to complete your shift.
timing ? are you at 14*-16* and using 92+octane ?
i think you have more mph out of it too, should trap about 110
110 mph shows about 300 rwhp in a 3200-ish pound car
my old notch w/ stock motor 4.10's and 75 shot went 12.52@ 108
so that should be a fairly comparable time to match
R
rigamaroles
British Columbia
Oct 30, 2006
  • Oct 30, 2006
Sounds like driver error. Just time and practice.
Edit:: What rpm were you at when you went through the 1/4.?
Modular2v
3,222
23
99
oklahoma
Oct 30, 2006
  • Oct 30, 2006
He still should be running ALOT faster than mid 12s! My 331 with c9 heads is running 12.0s@113 , he should be doing ALOT Better, like high 11s!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 30, 2006
  • Oct 30, 2006
E.T. doesn't matter as much as mph. Mph shows potential...
That mph still isn't very good for what you have, just practice with shifting...
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Oct 30, 2006
  • Oct 30, 2006
Driving should help that a TON!
aleborjas
610
#10
  • Oct 30, 2006
  • #10
i think is driver problems and the other thing is i think you are little short go down to 3.90 or 3.73 gears and get out of the hole at least 4500Rpm's 3k is too low
rd
3,316
63
109
Ocean Springs MS
Oct 30, 2006
#11
  • Oct 30, 2006
  • #11
You may want to take as much weight out of the car as you can, back seat, spare, junk in the trunk, etc.
The mph says you have some et to gain.
You may also want to try a couple dyno runs and check the air fuel ratio, etc, and adjust the timing to what runs the best.
lxwants12's
506
#12
  • Oct 30, 2006
  • #12
i agree with the driver practiceidea....even my vert 347 went 12.50's @111mph on nitto555r's witha 2.0 60foot....def launch harder...if ur suspension is up to par.....powershifting thru all the gears will sure take some off that et as well.....and yea i would run between 11psi and 14 psi in the tires
blue87lx
175
#13
  • Oct 30, 2006
  • #13
i crossed the like at almost 6000 rpm my light had just come on right before the light at the end of the track. my timing is at 14. i launched at 3000. i have lakewood upper and lower control arms. im gonna try launching higher this weekend. my buddy has basicly the same set up as me but not stroked just 40 over 9.5to 1 and he is going 12.4's launching at 5k
347 build on a D4DE block - Thoughts and Advice
  • bnero42
  • Jan 15, 2020
  • 2 3
12K
1965 - 1973 Classic Mustangs -General/Talk- Dec 17, 2020
LILCBRA
For Sale 93 mustang gt convertible 347 Astro A5
  • theYman
  • Sep 6, 2019
3K
Fox Body Mustangs For Sale (1979-93) Sep 30, 2019
theYman
A9L Not Commanding Timing?
  • 2ndlaw
  • Sep 25, 2019
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 7, 2019
2ndlaw
What's it Worth? Looking at a 1993 Foxbody - Opinion on Value
  • Hoytster
  • Jul 15, 2019
  • What is it Worth?!?!?
4K
What is it Worth?!?!? Jul 16, 2019
Hoytster
C
86 fox new engine stil ticks
  • Cntzombus13
  • Apr 9, 2018
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 12, 2018
90sickfox
