  • 1994 - 1995 Specific Tech
12#'s Too Much?
  • Thread starter Thread starter KBCobra95
  • Start date Start date Jun 20, 2006
KBCobra95
356
North Carolina
Jun 20, 2006
  • Jun 20, 2006
Right now I'm pushing 7-7.5 #'s boost and was wodering if 12#'s would be too much. Reason asking is because I have the 4.75 crank pulley KB sent me to get 8 #'s and I have my stock cobra crank pulley that will make 12#. My current meter is pegged and I was going this weekend to get a new SCT Big Mouth and re-tune and was itching for a smidge more HP. Would this be too much on my stock bottom end? Right now I'm making 465 to the wheels and won't be happy until I'm half way to 1k HP Thanks!
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jun 20, 2006
  • Jun 20, 2006
its just a matter of time before the bottom end goes. do you want to rebuild now or later??
i would see what #s you get with the mods planned without the added boost.
S/CBlack95GT
2,018
Tampa Palms, FL
Jun 20, 2006
  • Jun 20, 2006
You are already putting too much on the bottom end technically. If you dont run the car that hard I would go for it. I wish I had initially increased mine to 14 psi just for bragging rights and more mid range power.
KBCobra95
356
North Carolina
Jun 21, 2006
  • Jun 21, 2006
The only times it gets run hard are at the dyno and every now and then i get on it just to feel the power
(try to hear the whine )
95strokerPSU
986
Sacramento from Philly
Jun 21, 2006
  • Jun 21, 2006
If it's not your daily driver and you can afford to fix if it does break, then by all means crank it up some.
Methodical
1,192
11
59
Clinton, MD
Jun 21, 2006
  • Jun 21, 2006
That is the key. If you can afford to fix if it breaks and you can afford to be without the car.
KBCobra95
356
North Carolina
Jun 21, 2006
  • Jun 21, 2006
It is not my DD. In fact I Rarley drive it at all. Cept to go to shows and what not. Would low mileage be an issue? This car has always been a garage queen!
mytight95
2,605
Dothan,Al
Jun 21, 2006
  • Jun 21, 2006
would help, better bearings etc., less stress has been placed onthe rods etc. over their lifespan as well......
jason
KBCobra95
356
North Carolina
Jun 21, 2006
  • Jun 21, 2006
Since the last tune of 465hp I have: changed to a romac balancer, Msd billet distributor (stator going out), tighter belt (belt slip on the dyno), 4.81 crank pulley (was 4.75), new motor oil, transmission fluid, gear oil, tightning of exhaust (slight leak) and buying the SCT Big mouth meter. Do you think with these small mods (along with the tune) will gain the extra 35 HP I need for the 500 mark? If not I may have to chance and slap the 5.85 crank pulley on.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 22, 2006
#10
  • Jun 22, 2006
  • #10
it is very possible. i would try before you go with more boost.
bigcat
May 1, 2005
3,015
7200 feet
Jun 22, 2006
#11
  • Jun 22, 2006
  • #11
might as well try to see before you add more boost, IMO.
KBCobra95
356
North Carolina
Jun 22, 2006
#12
  • Jun 22, 2006
  • #12
I'll let you guys know when I get back this weekend! 12#'s or not I'm gonna have 500 hp! Hopefully the block will last, if not I will have a better one replacing it.
BlackVert
5,589
9
98
Bethesda, MD
Jun 22, 2006
#13
  • Jun 22, 2006
  • #13
mine is my daily driver
KBCobra95
356
North Carolina
Jun 22, 2006
#14
  • Jun 22, 2006
  • #14
How much boost are you running?
BlackVert
5,589
9
98
Bethesda, MD
Jun 22, 2006
#15
  • Jun 22, 2006
  • #15
i have the 8# pulley on, but i don't know how much boost it actually makes.
OT: did you see my other question to you in my spark plugs thread about datalogging your intake air charge? it may not be an issue though for you since it sounds like you don't drive it much. i have intake air temps of 230+ after driving for a while. that is when i ping. that is also why i started my other thread about coated headers
KBCobra95
356
North Carolina
Jun 22, 2006
#16
  • Jun 22, 2006
  • #16
No I didn't see your other thread until you pointed it out. So i'll post here. No I don;t have a way to datalog my intake temps. I can drive for 2 hours staright and have no pinging probs. My car has a straight 11.5 A/F ratio (custom tune) so I guess he made sure i wouldn;t have any of those probs. he just told me not to make too many freeway blasts, cause that is what heats up the air so much?
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
