- Nov 29, 2004
- 113
- 0
- 16
What would you guys spend it on(car). Can be performance or visually enhancing. BTW ive got bbk x pipe and flowmaster cat back, and a k&n...
95silvergt5.0 said:What would you guys spend it on(car). Can be performance or visually enhancing. BTW ive got bbk x pipe and flowmaster cat back, and a k&n...
if you take your time, and STUDY the "total package" before you start diving into engine mods.Couldnt have said it better myself, if your looking for the best price on tires (315x35x17) look on www.tirerack.com for the "summitomo" specialGreen 94 5.0 said:go with afs for the wheels.....the 17x9 front and 17x10.5 wheels look gorgeous on our cars. the 10x5 inch wheel and correct offset fills the rear wheel wells perfectly. that will also allow you to run a 315-35 tire in the rear.
bimmertech said:fix/upgrade the stuff that is currently leaking/broken/etc...
example: oil pan leaking? go ahead and put a sumped 7qt pan. clutch is old and doesn't feel right? complete system overhaul.
if everything is perfect(i bet it isn't--noones is) then gears, intake manifold, u/d pullies, lowering springs, c/c plates
thats what i did. i fixed my oil pan gasket. i have to drop my tank to replace the filler neck grommit so i am replaceing my bad (i think) pump at the same time. doing all maintanince before other mods. all my pads and rotors are shot, so i figured since i need new ones anyways i am upgrading to cobra ones. only spending money once.Scott_95GT said:^^^ This is what you should do. So many people mod before they maintain/repair.
For example, I've had some extra cash to spend on the car over the last 2 months, and wanted FMS 3:73 installed. But I had other needs. I put new rotors and pads all around, had the tranny flushed & supercooler installed, fixed a suspension issue, and did a good synthetic oil change. It would have been easy to get some gears, or a nice MAF/intake package, ect, but I had to address other issues first.
It really depends on what "you" want.......some people are into performance....some love the visual.........If you only have 1200.00 then my suggestion is this........Gears for the performance......I think a lot of stanger's would agree that is a very noticable upgrade.......Use the rest for rims or new shoes.....or new hood......If you have only that amount and get into major mods you will need extra money for supporting mods...........just my two cents.....good luck and money well spent on the stang95silvergt5.0 said:What would you guys spend it on(car). Can be performance or visually enhancing. BTW ive got bbk x pipe and flowmaster cat back, and a k&n...
95silvergt5.0 said:what is the summitomo special...i didnt c it on the site
