12volt switched power?
  • Thread starter Thread starter doogie67
  • Start date Start date Jul 20, 2007
D
doogie67
69
Pennsylvania
Jul 20, 2007
  • Jul 20, 2007
I can't seem to find a 12Volt switched power lead to hook up my MSD inginition wire. All the leads either cut off voltage while cranking or drop to 8 volts. Is there a resistor or bypass that is reducing the power? I guess I will have to run a wire to the battery and put a on/off toggle in the dash. Any ideas?
D
D.Hearne
11,730
south louisiana
Jul 20, 2007
  • Jul 20, 2007
Did you check all the wires behind the ignition switch ?
Hack
1,945
Minneapolis
Jul 20, 2007
  • Jul 20, 2007
On my '70 there is a pink resistor wire in the key on voltage source wiring. When I wired up my Duraspark ignition I tapped into the pink wire right at the ignition switch. Right at the switch it's 12V.
I would say take the column cover off and probe at the ignition switch for 12V. You should find a switched source there.
edit: don't forget to put a fuse in the line and a grommet to protect the wire at the firewall! I'd hate to see you burn down your car.
second edit: D. Hearne was too fast! Beat me!
65fastbackresto
1,229
AR
Jul 20, 2007
  • Jul 20, 2007
I kinda like the toggle switch idea
Could add a degree of antitheft to your car rather easily. Even if you goofed and left the keys in it, they`d have to know the switch was there to start it.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 20, 2007
  • Jul 20, 2007
If I'm not mistaken, the coil wire in the engine bay is switch 12v is it not ?
BlwnGazkit
153
Richmond, VA
Jul 20, 2007
  • Jul 20, 2007
The coil should have a resistor wire in it somewhere that limits its voltage at certain times. Thats the resistor for those external resistor coils like we have...
Not to mention, if it was 12 volts keyed then when you draw more juice you might starve teh coil... I've done that before, wired in a new device and then couldn't figure out why the darn thing wouldn't start anymore!
BullittStangV8
1,104
NJ
Jul 20, 2007
  • Jul 20, 2007
MSD's instructions is to wire the "red wire" on the ignition box to the old + coil wire. (I assume this means switched 12v) Am I right now in that what you guys are saying that the old + coil is not 12v switched in this case? As of right now, and I have not started the car, I have the red msd ignition wired to the old + coil wire.
http://www.msdignition.com/pdf/6 series/6series.pdf
Under dash, I do have a tap into the 12v part of the ignition switch, I just havent used it, as I was going to use it to power a tach. But, since I went with a new fuse block, I dont need it. Should I then simply just use that tap as the 12v source? What about the old ignition wire (+ coil?). Just leave it un-used?
Big_B
121
Sacramento
Jul 20, 2007
  • Jul 20, 2007
I'm having this issue too with my new electric choke. It says specifically "do not" use the coil 12v. Looks like I gotta go through the firewall eh?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 20, 2007
  • Jul 20, 2007
I think you can wire it to the S terminal on the alternator. Any comments on that ?
BullittStangV8
1,104
NJ
Jul 20, 2007
#10
  • Jul 20, 2007
  • #10
Mine used to be run off the S terminal I believe.
S-Car-Go
332
San Jose, CA
Jul 20, 2007
#11
  • Jul 20, 2007
  • #11
The "I" terminal on the starter solenoid will give you a switched 12v source. I ran a wire under the radiator (followed the voltage regulator wires) and mounted the MSD by the radiator overflow.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 21, 2007
#12
  • Jul 21, 2007
  • #12
Don't run too many things off of this. If you want to run a lot of items off of this source you can use it to send signal power to a relay and get the power from the relay instead.
Tim65GT
1,149
West Texas
Jul 21, 2007
#13
  • Jul 21, 2007
  • #13
The + coil wire and the I terminal on the solenoid are the same. They get their voltage from the resistor wire off the Ignition Switch C (coil) terminal.
When cranking though, the solenoid provides the full voltage to the coil through the I terminal. Once running the coil receives 6-9 volts because of the voltage drop across the resistor wire.
You may measure 12v at the coil or I terminal with the key on and the engine not running. It depends if the points are open or closed. If the wire is removed from the coil, same thing, there is no load on the resistor wire, so there is no voltage drop. Get it?
For the MSD the main current draw is through the heavy red wire. The smaller red wire goes through the switched source (coil +) and does not draw alot of current, so leaving the resistor wire in is fine. It's just a "turn on" signal.
If you are wiring an electric choke (or other high current device) however, you would have to go through the firewall directly to the "C" terminal on the ignition switch. I would use a relay to prevent excessive current draw from that terminal though.
S-Car-Go
332
San Jose, CA
Jul 21, 2007
#14
  • Jul 21, 2007
  • #14
Learn something every day. I would swear I saw 12v with the car running, but it wouldn't be the first time I was mistaken.
So with the car running you should see a 3-6v between the pos battery terminal and the I terminal (and 6-9v I to ground)? I need to check this as soon as the car is on the road again.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
