13.764@101
Vex5.0
36
Janesville,WI
Hello all, I havent been on the boards much lately but my last topic was about me running 14.018. I recently went to the track and ran a 13.764@101. I wasnt spraying in first gear before but i did this time and had no problems with spin really. Is this a better time for what I have done?
thanks
well dropping from a 14.0 to a 13.7 is a deff imporvment. What was your MHP during your 14.0 run and your 60' times compared to now? That will help tell if you actually improved on your times b/c of traction or if the way you drove it this time gave you the better times.
Basically stock with a 75 shot...looks about right to me considering the car should be running high 14s as it came from the factory, in a good state of tune. You've dropped at least a full second from his time.
You would do better with an off-road h-pipe. Getting a bigger fuel pump and fuel pressure regulator and going to a 100 shot would help ALOT.
