  • 1994 - 1995 Specific Tech
13 inch rotors
  • Thread starter Thread starter paxton86
  • Start date Start date Jan 6, 2006
P
paxton86
38
  • Jan 6, 2006
to switch from the factory 10.8 to 13 inch rotors, what all is needed?
rustang94
281
Milwaukee WI.
Jan 6, 2006
  • Jan 6, 2006
Cobras? Caliper, caliper bracket, and brake hoses. Simple install
P
paxton86
38
  • Jan 6, 2006
i knew the hoses and caliper bracket, but wasnt sure about the caliper itself....
i thought you can use the stock caliper, but just needed the bracket?
RFMustangGT
294
Knoxville,TN
Jan 6, 2006
  • Jan 6, 2006
I think someone somewhere has a braket kit where it moves it to use 13 inch brakes. if you buy a set of cobra calipers (and most are like thing) the bracket is made into it. I order a front kit front stangsuspension.com and it came with brembo cross drilled/ slotted rotors with the cadnium plating (I think that was it), cobra calipers (which have pads already in them), and maximum SS lines. with tax and shipping it was like 500 I think. I paid top dollar for it but I'm over all pleased with it. I know you can find it cheaper out somewhere but the guy I delt with was real cool. only prblem I had was getting my rotors in. some backorder issue with them.
blksn955.o
3,263
st.louis mo 314
Jan 6, 2006
  • Jan 6, 2006
Were would you go to just get the bracket??
I have some 99+ calipers and I know they will just bolt up fine (with alittle grinding) to my stock spindle. However, I have been kicking around getting the 13in rotors and using the 99+ calipers with them.
My thinking is this.
the 99 caliper has larger twin pistons over the the cobra ones. The reason the cobra kit is better is the larger rotor that gives better mech. advantage...so the same bigger rotor and a caliper with a larger set of pistons "should" work better correct?
bimmertech
1,123
merriam, ks
Jan 6, 2006
  • Jan 6, 2006
the bracket kit in question is for the rears(gt/v6) only. i wish someone sold brackets for 99-up gt/v6 calipers for 13" rotors.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
C
For Sale Mint 1993 Calypso 5.0 Convertible
  • Chrispy62
  • Aug 22, 2026
Fox Body Mustangs For Sale (1979-93) Aug 22, 2026
Chrispy62
C
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
