17x10.5's w/ 315/35r17
ive seen a lot of stuff about people having problems w/ aftermarket exhausts but what if you have a stock system...
will these wheels fit w/ stock exhaust and the quadshocks in place? if not can i take off the quads and still be able to hit 2nd gear hard even tho im on stock LCA's... i plan on changin LCA's when i do lowering springs...
Have my 17x10.5 with the 315/35's on with quad shocks, on stock lca's and the MM xd lca's with zero issues. I'm running a borla catback which is a tad larger and cuts into the wheel area more and it clears fine.
RoadconeTuning said:
i know that... i plan on running some CHEAPO Suckyhomo HTZR whatever they are...
They will clear. I just put 315s HRTZ on my car, no problems at all. there actually not that bad of a tire either.
I'm running 10.5 deep dishes and 315/35/17 Goodyear GS-D3s - clears stock catback with no rubbing - just have to be patient to get it lined up. Later added Steeda catback, also clears no problem.
Here's some before & after pics
Before...
photodisplay.php
After... :D
photodisplay.php
photodisplay.php
