180 T-stat in 02GT?
02GTRX
I told an admin to shut up...now I live with the S
Sep 27, 2004
213
My car starts getting really hot driving around town in this 104+ weather, Im wondering if I can just drop a 180 thermostat in there to fix this problem, will it affect anything in a bad way? My car is stock.
stangman said:
you'll need to have the fans programed to come on at a lower temp to make it effective
What he said ^^
Although your gauge will read lower on the highway with the 180, around town the temp will go just as high as with the stock thermostat unless you program the EEC to turn the fan on sooner.
Athough I'm not in an extremely hot weather enviroment, the 180 degree t-stat helped lower the temp not only in the other seasons, but the summer as well. It does get decently hot at times here and my car now operates one letter lower in the temp gauge all year around. I don't have the fan mod or chip upgrade either, which I'm sure would help even more. So in my case the earlier opening of the t-stat helps keep the engine cooler. I also keep the antifreeze fresh by changing every 2 years. BTW, I used the Ford 180 t-stat from the lightning. Fit and operationally works great.
