Gearbanger 101 said:18's all the way around and equal size tires (275/35/18) is your best bet. Going the same size all the way around assures that you're still able to rotate the tires around for better wear and longer tread life. Pick a tire that fits as squarely on the rim as possible if handling is your main concern. A wider tire may lay down a slightly wider foot print, which is great for rear wheel traction, but a wider tire in this range is also going to have a taller sidewall, which will flex that much more under hard cornering. You may also want to look into a set of lowering springs as well, since even with the same overall diameter, an 18" wheel and tire combo is going to appear smaller than a 17" combo.
clear your pm box, important
