1966 C4 to Toploader Speedometer Cable Location?
fasttback
471
Northern CA
Does anyone have a pic or can explain where the speedometer cable is routed through after it leaves the firewall and before it reaches the tail end of the transmission. This was a conversion from a C4 to a toploader. The catalogs claim the 1966 automatic and standard trans use the same speedometer cable. I do have longtube headers, so some modification might be needed?
Dennis112 you should have some info on this.
Wish I could offer "good help", but I used a 68' 4 speed cable on mine. I routed it from the firewall, OVER the tranny in front of the cross member, and it makes a deliberate sharp curve into the tranny on the passenger side.
Good Luck!
