1966 Mustang 289 flywheel info needed
Hi, Need some info/help
Have a 1966 mustang coupe 4 speed top loader
I picked up a Rebuilt 289 that was in a 1968 mustang with an automatic trans.
It has a wide heavy damper wheel, so I want to match up the correct weight manual fly wheel and not have any vibration problems.
My old 289 has a smaller damper wheel, can I use my existing fly wheel or should I get one that is heavier to match the damper??
What kind of weight fly wheel am I looking for???
Thanks in advance for help and info.
...Harley
You just need to make sure it's 28 ounce offset weighted, not 50 ounce. The wide damper with the internal offset weight is supposed to make up for the heaver rods and 3/8 inch bolts on a hypo engine that spins to a higher rpm, but it can be used either way. You may want to look under the oil pan to see what you have, also a great time to check bearing clearences, trust no one on a rebuilt engine.
The flywheel or flex plate should be marked for it's offset weighting, a balancing shop could test it for you or 1967 and older should be correct. I would have it tested if going used. With new you should be able to tell them what you need. Nothing to check on the damper, weighting wise, but check the condition of the rubber between in inner and outer band, and if the outer band has slipped or not, check that the timing marks are correct at TDC. There are a lot better dampers out there aftermarket, and you could get some cash the the old one, they can also be rebuilt.
