1969 stang deep sump oil pan
i would go with the stock pump as it will do just fine in your engine, but i would also go with the larger oil pan as well as extra capacity is always good. i would however suggest rather than a deep sump pan, you use instead a "T" style pan. that way you get teh extra capacity, and you dont lose ground clearance.
this is the pan i recommend;
http://www.summitracing.com/parts/MOR-20502/
