1971 351 W????
  • Thread starter Thread starter chgovfk
  • Start date Start date Jun 22, 2009
chgovfk
531
28
59
AZ
Jun 22, 2009
  • Jun 22, 2009
Hi -
I just bought a 1971 Ford galaxie w/a 351 2V with 90K original miles....he claimed it was a cleveland ....but the water neck is vertical ...not "up" and the valve covers aren't slanted up either.....so I figure it's a Windsor.....it's a "time capsule"....I plan on pulling it....it runs tight ....reworking the heads....new cam and run it in a 90 thru 93 mustang.....anyone know the spec's on this year?...
Frank
D
D.Hearne
11,730
south louisiana
Jun 22, 2009
  • Jun 22, 2009
The compression ratio is around 9 to 9.5 to 1. Basically the same heads the 69 4bbl Windsor had, just slightly larger combustion chambers. Port the heads, slap a good cam in it, add a high rise intake on it, plus a better ignition than the points it's got. You'll have basically a "lightning" 5.8 motor.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 22, 2009
  • Jun 22, 2009
Sounds like a Cleveland to me.
D
D.Hearne
11,730
south louisiana
Jun 22, 2009
  • Jun 22, 2009
count the valve cover bolts too, Windsor's have six, clevelands got eight. Could also have a 400 too that year.
rbohm
6,698
550
204
tucson,az
Jun 22, 2009
  • Jun 22, 2009
does the coolant neck come out of the block or the intake? if the intake then it is a windsor. look at the fuel pump mount, are they horizontal or vertical? if vertical then you have a cleveland or other 335 series engine. look at the timing cover, does it separate from the block or is it cast in? if separate you have a windsor.
chgovfk
531
28
59
AZ
Jun 24, 2009
  • Jun 24, 2009
351 / W
[Thanks for all of the help.]....I plan on posting a few pictures ....I may have made a mistake about saying the that water inlet/ neck is vertical....it's Horizontal...I pick up the car this Friday.....counted the bolts on the valve covers....(6) Six.....plus they are the smaller covers....so it's probably a Windsor........my plan is pretty much what was suggested here.....pop the heads and have them re-worked....SS valves ...new springs ...I'm looking for a high HP .. torque monster....a real real lumpy flat tappet cam.....gear drive (I know they are not good unless it's a drag car) ...but I need that noise....but have it streetable ...pwr steering....air....any suggestions are greatly appreciated....
rbohm
6,698
550
204
tucson,az
Jun 24, 2009
  • Jun 24, 2009
you do have teh windsor. just a suggestion, rather than spend the money refurbishing stock heads, go out and buy a set of world products windsor sr heads. the cost will be about the same and you will gain about 40hp or so, and will have room for even more if you like.
chgovfk
531
28
59
AZ
Jun 24, 2009
  • Jun 24, 2009
Thanks ...I will look into that...hey...hate to bug ya ... but...any suggestions on a flat tappet cam kit?...I was going to use the stock rockers ......I figure for what I need ...for the lumpy affect....it's Ok....I at first bought a 78 351M motor out of a ranchero ....there's a guy I found who runs the hot rodder program here in AZ at UTI ...he was going to rebuild that for me....but when I went to the speed shop to buy a 400 crank ...they said I needed a core and the cost of the crank + the core was what I bought this original 71 ltd w 90K on it and it has 351W.....but for that 351M motor he suggested a cam .530 Lift and 282 deg of adv duration ...for the choppy idle I would like ......I plan on running an average 5.0 mustang rear end in it......what you think?.....thanks ...sorry about all these questions ...I'm more of a paint and body person...worked at Bod shop when I was a teenager....
frank
K
Engine 93 gt new 351 w moter put in and installing ace's kill shot EFI. It turns over but Wan't start? Need Help.
  • kimscales
  • Jun 1, 2024
2K
Fox 5.0 Mustang Tech Jun 2, 2024
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
5K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
Swap or Build?
  • Cammer429
  • Oct 10, 2020
3K
1996 - 2004 SN95 Mustang -General/Talk- Oct 18, 2020
weendoggy
