1976 Mustang Ii Flexplate
skippermccoy
holly,mi
Visit site
I am having a problem with the starter chewing up the flexplate. I have ordered a new flexplate from B&M they are saying part number 50236 is the correct one. It says it is a 157 tooth but I am showing I will need a 141 tooth. Will the 157 work? I am going to change the starter at the same time.
  • Sponsors(?)
LILCBRA
3,269
2,471
174
49
Marietta, Ga
The 157 tooth flexplate will not work with a II bellhousing, it is a bigger diameter than the II's 141 tooth flexplate.
skippermccoy
holly,mi
Visit site
I found a 141 at napa. I need to return the 157 that will be here today and hopefully my napa one will be here by the weekend. Thank you for verifying this. I am just wondering if the previous owner who had a carbuerated gt motor in there used the larger flexplate and that is why it is chewing up startes and the flexplate. I will be able to lay the flexplates together and see how much bigger it is then the 141.
LILCBRA
3,269
2,471
174
49
Marietta, Ga
I'm going to say if he used a later model 302, he would have had to have used a later model bellhousing. If not, then if he used the II flexplate I would hope they had it rebalanced to the later model's 50 oz imbalance instead of the II's 28 oz. My advice is to verify what engine and bell you have and act accordingly. You may have to have the 141 tooth plate rebalanced to the later model engine? Also, be sure to check engagement depth of the starter and compare it to your flexplate depth from the bell. IIRC, all Ford starters have the same tooth count, but their depths <i>may</i> be different. It seems I seen a chart somewhere with starter part numbers and what differences there were, but don't recall where it may be or what differences all of them have. A quick search on Google netted this information: http://www.bcbroncos.com/ford starters.pdf Hopefully that can get you started (no pun intended) in the right direction! :)
skippermccoy
holly,mi
Visit site
I have both size flex plates and will have the trans pulled in the morning. I can then finally see what parts the old owner had in it. The 28 oz is what I will need it is a mid 70's block crank etc.. Thank you all for the help and fingers crossed it will be sorted tomorrow and another cobra back on the road.
skippermccoy
holly,mi
Visit site
No luck. Turned over great a couple times and then grinding again. Still doing the same thing. I replaced flexplate and starter. Only thing I used from old motor trans was the plate in the between them. I guess that will be next weekends project putting a new plate between engine and trans
king combo
165
46
Minnedosa Manitoba Canada
I would almost guess, that he may have retained the II tranny and flexplate(Rebalanced) if so, You need to make sure the nose cone on your starter is matched to the II transmission. Ford did have a few variations of it, trust me, I had 5 starters before my combo would work. You just need the starter with a slighly longer nose cone if I remeber it correctly.
Thunder612
Ga
Hi, I have a '77 II and need to get the flexplate rebalanced to 50 for my 302 which is an '86 model. Do you have any idea where/ who could do this?
LILCBRA
3,269
2,471
174
49
Marietta, Ga
Welcome to the site!
Art Carr is the only aftermarket supplier as far as I know. BUT, if your engine is torn down or if you're looking to freshen up the bottom end, you can take the flex plate and crank in to an automotive machine shop and have them rebalance the flex plate. Or, if you really want to, you can take the whole reciprocating assembly and have them balance it as a unit. A quick google search of "flywheel balancing 30064" (since that's my zip code....) brings the first result as Scott's Auto Machine in Fayetteville.
I'd just start calling local shops and asking if they can do it and how much for their service so I could compare and make my decision.
Good luck! :)
Reactions: 2 users
Enzio
Dang it. I was hoping mine would get 3 more inches
May 14, 2019
841
664
103
65
Minnesota
I'll be the one to ask it...Pictures Please?
Reactions: 1 user
