1979-1993 Fox Mustang Torque Index
Admin Dude
Jan 4, 1985
43,531
21,699
234
Box behind Walmart
Ok boys and girls. This is one of the things that many of us talk about, some of us have started, and none of us have ever really completed.
So...
Here's the beginning. I will update as you guys add, update, or delete things through your comments and contributions. I'll even take whatever spreadsheets some of you guys probably have lying around. We'll populate this thing and make it searchable at the same time.
I have books. You all got books... A few items a week and it will all be catalogued in no time.
Read and Bleed everybody! I know that not all of these values are correct but I wanted to start somewhere.
Edit: I've removed this table because the one in the next post is better.
Already, I'm making changes... Oooops! But look what I've found! I think it will be better this way, Agree? Disagree?
Lemme know. Also... I have only validated a few of these lines by spot checking. So by all means... Lemme know where the errors are. Last note that I've based a lot of this on a 1989 GT. There may be variance between all the years and not all the values listed are 1989 specific.
This is a "gathering" of info from multiple threads including the ones already listed in the Technical Index.
ComponentTorque Value (ft-lbs)Hardware Size
A-Arms to Crossmember110-150
ARP Head Studs (ARP Moly Lubricant)65
ARP Head Studs (Motor Oil)85
Alternator Bracket to Head7/16-14 x 1-3/4"
Battery Hold Down Bolt6mm x 1.0 x 55mm
Bearing Adjustment Nut (Initial)15-20
Bearing Cap Bolts60-701/2-13
Brake Caliper Banjo Fitting20-30
Cam Bolt40-453/8"-16 x 1.25" to 1.5"
Crank Pulley35-503/8"-16 x 1" to 2"
Crankshaft Pulley Bolt103-133M-14
Driveshaft Bolts70-9512-point, 12mm x 1"
EFI Throttle Body/EGR Spacer12-185/16"-18 x 3.5"
Flywheel/Flex Plate75-857/16"-20 x .75" or 1"
Front Sway Bar Bolts35-50M10 x 1.5 x 38mm
Harmonic Balancer90-1107/16"-20
Headers26-323/8"-16 x .75" to 1"
Intake Manifold23-255/16"-18 x 2"
K-Member Bolts85-100M16 x 2.0 x 117.5mm
Main Bearing Caps60-707/16"-14
Motor Mount to Engine35-607/16"-14 x .75"
Oil Pan Bolts6-91/4"-20 x 1" and 5/16"-18 x 1"
Oil Pump Bolts22-323/8"-16 x 1"
Pedestal Rockers18-255/16"-18 x 2"
Rear Differential Cover Bolts (Stock)28-385/16 x 18 x 3/4"
Rear Quad Shock Axle Housing Mount Bolts8512mm x 1.75 x 70mm
Rear Shock Axle Housing Mount Bolts8512mm x 1.75 x 70mm
Starter Bolts18-243/8"-16 x 1.25" and 2"
Thermostat Housing (Bottom Right)15-225/16-18 x 1 1/4" with split lock washer
Thermostat Housing (Top Left)15-225/16-18 x 1 3/4"
Transmission Mount to Crossmember30-40M10 x 1.5 x 20mm
Transmission to Bellhousing Bolts28-3812mm x 40mm x 1.75 pitch
Valve Covers10-131/4"-20 x .75"
Water Pump Pulley15-225/16"-24 x 1" to 1.25"
Wiper Motor Screw1.25" long blunt sheet metal screws, 1/4"-14 thread
Camshaft Thrust Plate to Engine Block Bolts108-144 in-lbs1/4"-20 x 3/4"
Differential Shaft Lock Bolt15-305/16"-18 x 1"
Pressure Plate to Flywheel Bolts12-24
Timing Chain Cover Bolts12-18
Pinion Bearing Preload8-14 in-lbs
Oil Filter Insert to Engine Block Adapter Bolt20-30
Quarter Window Nut9-18 in-lb
Why do they say in the Torque Value (ft-lbs) for let's say the A-Arms to Crossmember why does it say 110-150 why not just say 150?
It really comes down to hardware and application. For parts like the A-Arm there is a minimum torque required to ensure that the component functions correctly and maximum torque that if exceeded can case it to [not] function correctly.
If you're somewhere [in the range] then you're operating that component inside of conditions for which it was designed and tested.
Another reason for torque ranges is variance from one tool or another or even the operational environment. Aircraft for instance: Things begin to snap and break through heat cycles. The actual break torque on a piece of hardware is wildly different at different temperatures. The final torque on hardware would take the expansion and contraction into account as well. Big difference in temp between 30,000 feet and sea level. O_o
Just for kicks I'll use the Pill Bottle example:
At 100 ft/lbs of torque, the pill bottle lid is securely fastened to the bottle. If you were to exceed 160 ft/lbs of torque on the cap, you will break the threads on the cap or break the bottle. So we set operational range from 100-150 ft/lbs for the Pill Bottle. :D
