1985 mustang GT t-top 351w
1985 mustang GT t-top 351w w/videos
selling my 85 GT t-top car because i found something else i want.car is located in loretto t.n.38469.im asking $6500 reduced from $7500.mods are:
351w .040 over
keith black forged flat tops
compcam 280H magnum cam
rpm airgap intake
holley double pumper
351 heads milled,ported,and polished
heads have all new valves,springs,etc. matching the cam
holley blue pump
new water pump
new HEI distributor
5" autometer tach w/shift light
14" electric fan w/thermostat
engine has been balanced and blueprinted
rods shot-peened
351 deep sump pan
4" cowl hood
new oil pump
new master cylinder
new brake lines
new pads
new shocks
new steeda firewall adjuster,cable and quadrant
hedman shorties
off raod x-pipe
flowmaster 40's dumped
trans:
tremec t-5 rebuilt w/ t5z gear set
rear end:
8.8 rebuilt w/ new locker diff
31 spline moser axles
4.10's
5 lug conversion
new clutch
new flywheel
new gas tank(pick up tube in tank enlarged)
a/c eliminator kit
new battery
new door hinges and handles
new motor mounts
95 cobra r wheels
new fuzion zr1 tires(255/45/17)
im sure im forgeting somethings.
the bad:
2 wheels are starting to flake some.
needs a brake power booster
needs a drivers door lock actuator
paint looks decent from 15 ft,but could use some tlc.
this gt came with most options available in 85.pw,pdl.t-tops,atc.does not have a/c or cruise anymore.was originally light regatta blue.121k on body and 1941 miles(on trip meter) on entire drivetrain.you can contact me by replying here or calling 931-853-4121 ask for shawn.thank you for looking.
