1986 GT with a 93 Upper Intake....
casper98gt
66
NH
Sold it to a buddy because in a Mustang builders book i have says they give good power inscrese. He says it has a good difference in power, but it idles horrible, and its jerky and smells rich and gets hot.
Any thing?
I don't think there is any material difference between the '93 upper and the '86 upper? A '93 from a cobra is a different story and would require the lower also. Idle / jerky etc probably be vacuum related
I just removed it from my car. I have a 93 that just recived a trickflow. He has a stock 86 GT. I remember somewhere that they flow beter. So i let him install it. He installed and came to my dealership and it runs like junk. I cant be sure anything didnt fall down or something like that. But my car ran like a top before i removed it. TPS didnt move or anything. He put his EGR on thats all. Maybe he cleaned out the egr. But i dont know. I was hoping someone may have had this problem.
Sigh, You do NOT adjust the TPS!!!!!!!!
PLEASE STOP SPREADING THAT RICER BS MYTH!
The '86 *uppers* were unique. They were tuned more for the low-end and mid-range. In other words, they were tuned more for REAL WORLD DRIVING! But, real world driving power doesn't sell cars like better qtr mile times. So, the 87-93 uppers were tuned more for mid-range and high-end. Also, the E6 heads, which again are better for real world driving, were replaced by the truck E7 heads. Again, to get better qtr mile times.
That's why a stock '86 5.0 is FASTER in the 1/8th mile, from a dead stop, and in the street were you can't "light up the tires".
So, the "massive" gains that the 87+ upper will give are mainly BS. You'll see around 5+ HP above 3K rpms. As I've said MANY times, if someone is going over 3K rpms on the road, they don't have a clue on how to drive!
Uhm, I did switch to the 87+ upper and then to the Explorer intake. Yea, I gave up low-end and mid-range power. BFD, the 5.0 has plenty as it is. :) But, my point is that the "massive gains" that people often claim are as PURE BS as "adjusting the TPS".
About the TPS:
Read:
http://www.veryuseful.com/mustang/tech/engine/Mustang-TPS-FAQ.html
From someone that has an MS degree in Computer Engineering and does this stuff for a living - me![/QUOTE]
Wow.....you have alot of time on youre hands and to me that was a complete waste of reading. Being a ford tech what i read on Mustang forums...i kinda take with a grain of salt. We know you cant adjust a ford tps. Thats a given. Aftermarket TB's do have a provision on them in which the TPS is bolted to that has slots built in to adjust them.
the 86 uppers have a smaller TB diameter - about 55mm or so and do not have the cast in deperessions for the EGR coolant chamber like the 87+ intakes - other than that the runners appear to be the same size but I have not measured them with a cc burrette. My eye is pretty good. The 86 upper could be ported to accept a 65mm TB, gasket matched and should then perform the same as a 87-93 upper.
