1986 mustang no start
  • Thread starter Thread starter foxyjamss221
  • Start date Start date Oct 11, 2025
F
foxyjamss221
Woodstock ga
Oct 11, 2025
  • Oct 11, 2025
So! Hello guys I have changed the starter before I got the car and it was running basically fine, like sometimes when cold it took one or two cranks but it needed work so what do you expect. It then started to turn on and then stall unless I spammed the gas pedal to work it up. Finally it stopped starting all together-
I've taken out the CFI and cleaned everything leading to the engine including the injectors
I replaced the fuel filter, spark plugs, fuel pump, and ofc the battery but it still won't start it will crank but not turn over. I did a spark plug test by grounding it and cranking, and there was spark just not blue so maybe it's the distributor, ignition coil idk rlly. Any help would be appreciated.
DadLife0724
I vote for a new bung hole.
Mar 22, 2024
436
291
73
Cooperstown, PA
Oct 11, 2025
  • Oct 11, 2025
In the Fox forum, the one you posted this thread in, click the "fox 5.0 mustang tech" thread. There's a no start checklist. That oughta get ya straightened out.
Admin Dude
Jan 4, 1985
43,531
21,699
234
Box behind Walmart
Oct 12, 2025
  • Oct 12, 2025
Post pics of the engine bay.
rednotch
I'd like to remain having one chocolate starfish
1,495
698
143
south jersey
Oct 12, 2025
  • Oct 12, 2025
86 cfi would be 3.8's only if I remember right? did you try using starting fluid at all to see if it would fire? That will help pin point if its spark, fuel or something else.
Reactions: Noobz347
F
foxyjamss221
Woodstock ga
Oct 13, 2025
  • Oct 13, 2025
I'm trying tonight! I can let yall know
Reactions: Mcmahst
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
