1987 lx clutch help
denieric
14
i have a problem with my clutch, when i go to change gears i have to press the clutch down to the floor to change gears, i have been told that it is the clutch cable that needs adjustment but were do you adjust the clutch cable.
Sounds like your cable may have stretched? Usually it's the other way around; the clutch engages too high as your clutch wears. You can adjust for that by simply lifting up on the clutch pedal until you hear a click. Not sure what to do in your instance........
