Expired 1987 Mustang Racecar Ai, Aix, Nasa, Scca, Hpde
66gtfb
I've finally decided to sell the race car. Lack of time and funds to enjoy. Very fast, reliable and well balanced. Lots of money spent on the right go fast goodies. Here's the list:
Engine:
Stock block 347 built by AD Performance
Mahle flat top pistons (10.7:1)
Comp XE282HR cam/Comp roller rockers
World Senior 58cc aluminum heads (2.02/1.60)
BBK shorty headers, offroad H-pipe, Flomaster 3 chamber mufflers. Will pass any db test.
Edelbrock RPM II intake manifold
Accufab throttle body
FMS 36lb. injectors
Canton road race oil pan, pick up and high volume pump
Megasquirt 2 stand alone engine management w/ wide band O2
Misc front engine bracketry to remove A/C, smog pump, etc
Brand new Spec stage 3 clutch, pressure plate, TO bearing
Lightweight Fidanza flywheel
MAC cold air kit
MSD 6AL box & coil
Remote oil filter with cooler
Power steering cooler
Summit aluminum radiator
Transmission:
Standard WC T5
Steel front bearing retainer
Rear cluster support plate
Road race 5th gear set
MGW shifter
Rear end
Stock 8.8, 28 spline
Recently rebuilt with 3.73 gears
SN95 Mustang width axles
TA Performance aluminum girdle
Front suspension:
MM sway bar, relocation bracket and support
MM K-member
MM front offset, SN95 control arms
MM coilovers with Koni SA & Hypercoil springs
MM camber/caster plates
MM strut tower brace
MM thru bolt bump steer kit
Wilwood 6 piston brakes, 14" rotors
MM full length weld in subframe connectors
18" Saleen 5 star wheels with Hoosier 275s
Adjustable brake bias control
Rear suspension:
MM panhard bar
MM torque arm
MM coil overs wth Koni SA & Hypercoil springs
MM adjustable sway bar
MM lower control arms
MM rear shock mounts
Cobra 11" brakes
Interior:
2 Momo Start seats
6 point harnesses
Battery relocated behind passenger seat
12 point rollcage with additional bracing and door bars(painted cage and interior)
Autometer gauges
Window net
Upgraded pedals
Quick release steering wheel
Gutted doors
Custom switch panel (still needs to be wired)
Exterior:
3 year old paint
H.O. Fibertrends cowl fiberglass hood w/ carbon fiber hood vent clear coated for UV protection
Weinerdog fiberglass front end w/ splitter
ABS plastic side skirts (mimic the ones from Agent 47)
Custom adjustable rear spoiler
Lexan rear window
Fiberglass front fender flares
The car is located in Bend, OR. I may be willing to travel a reasonable distance to meet a buyer. Please feel free to contact me with any questions. I'm looking for $17,000 or best offer. five four 1 eight one five-4587
