1988 MAF Conversion
  • Thread starter Thread starter dangrego
  • Start date Start date Sep 26, 2009
D
dangrego
45
  • Sep 26, 2009
Hello, looking for guidance on correct size MAF and correct computer for converting an '88 5.0 EFI manual transmission to Mass Air...I already did the conversion two years ago with crappy results and am considering throwing out the remanned A3M1 computer for something different and also replacing my 75mm PMAS MAF meter (yes, cal'd for 24 lbs) with a different brand and/or size?
Details:
24 lb injectors
70mm throttle body
BBK cold air induction
Edelbrock RPM Performer II upper and lower intake
Any insight out there regarding?
D
dangrego
45
  • Sep 26, 2009
...another thought, the computer used for my unsuccessful MAF conversion came out of a car with 19 lb injectors factory...do i simply need to find a computer that came factory for cars like the cobra which used 24 lbs?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 26, 2009
  • Sep 26, 2009
93 Cobra Computer was used with 24lb injectors.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 27, 2009
  • Sep 27, 2009
Using 24 lb injectors with your setup will not bring any HP gains with it. The stock 19 LB injectors are good to 260-280 HP with some safety margin.
Use an aftermarket MAF that matches the injectors. Mistmatches just mess up the air/fuel mixture.
The best MAF for your combo would be one of the following:
94-95 Mustang GT MAF - $40-$100 at the junkyard. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter Kurtz Kustomz Motorsports, Inc. KKM Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
Try AutoZone and ask for 81413 - Spectre / 3 in. Aluminum Intake Mass Air Flow Sensor Adapter at $12.00. You may have to order it online.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1994-95 Mustang 3.8L F2VF-12B579-A2A,
1992-94 Crown Victoria 4.6L F2VF-12B579-A2A,
1994-95 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1992-94 Town Car 4.6L F2VF-12B579-A2A,
1992-94 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
vristang
4,933
101
124
Seattle
Sep 27, 2009
  • Sep 27, 2009
Details:
24 lb injectors
70mm throttle body
So, how was the MAF swap unsuccessful? What problems are you having?
If the MAF meter you have is properly calibrated for your injectors and ecu, then you shouldn't be having issues with it.
Did you buy the MAF new or used?
Have you double checked the part numbers with the manufacturer to verify you are using the right meter?
When running 24's one of the best ways to do this is by using the 93 cobra setup.
ecu - X3Z
Inj - 24Lb
MAF - F1SF/afh70, which is in a 70mm housing.
However, this involves buying more parts, which I would recommend until you have positively identified the source of the problem you are having.
jason
D
dangrego
45
  • Sep 27, 2009
jrichker, am temped to go back to 19; however, I want to make sure that 24 is not still good since I have, as not mentioned earlier, reworked heads with oversized valves etc and upgraded headers/exhaust also...any problems forseen with using the '93 cobra computer and just staying at 24 lbs?
vristang
4,933
101
124
Seattle
Sep 27, 2009
  • Sep 27, 2009
The 93 Cobra computer will require a 93 Cobra MAF.
With 24's, that setup will work well.
D
dangrego
45
  • Sep 28, 2009
howdy again, would a 75mm MAF work as opposed to a 70mm? (i have one ordered and it is a 75mm...if it is prudent, I will surely send it back for a 70mm). Also, fyi, my TB is a 70mm.
vristang
4,933
101
124
Seattle
Sep 28, 2009
  • Sep 28, 2009
It isn't so much the size of the MAF that matters, but rather the calibration.
Did you order the MAF for an A9L ecu, or for a X3Z ecu?
They aren't the same calibration...
No offense dude, but you're kinda bouncing all over the place.
What is wrong with your car? Diagnose the problem before dumping money at it...
Folks have asked some specific questions in this thread, trying to help you get things figured out.
You've pretty much ignored all of it... kinda rude?
D
dangrego
45
#10
  • Sep 28, 2009
  • #10
sorry 'bout that.... Currently running an A9L equivalent computer with 24 lb injectors and a MAF cal'd for 24 lbs...have been having really bad idle surge and running super rich even after all the diagnostics, sensor checking/replacing, and tuning. Anyways, my MAF got crushed accidentally the other day so I have to throw money at a new one and think I will just stay with the 24 lb injectors and 75 mm MAF....guess I do need to make sure it is cal'd for the '93 computer that I plan on aquiring as well. thanks again! any thoughts? V/r
Mustank
166
Germany
Sep 29, 2009
#11
  • Sep 29, 2009
  • #11
If you already have an A9L ecu, there's no reason to change it. Just get a new MAF then double check all of your wiring.
Have you gone through the Surging Idle Checklist?
edit: Wait...what do you mean by A9L "equivalent"?
D
dangrego
45
#12
  • Sep 29, 2009
  • #12
oh yeah, i've ran the surgin idle checklist a couple of times....the A9L equivalent is a Remanned A3M1, F3ZF 12A650 DB...got it from Brother's Performance.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 29, 2009
#13
  • Sep 29, 2009
  • #13
Posted via Mobile Device
Did you solder you connection on the MAF conversion?
D
dangrego
45
#14
  • Sep 29, 2009
  • #14
yes, not at first, but a few weeks ago, i went through and redid all my connections the right way with solder, but didn't solve the problem.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
  • dan50
  • Jul 18, 2026
dan50
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
