SOLD 1989 Coupe
stockmustang
Ok guys..I'm just trying something here...This car isn't for sale I am looking to trade this little Beast for something else But if I had to put a price on it I would say between $7000 and $7500 ..I have a truck and I don't ride Bikes I'm not looking to trade up only same or less with some boot
This is a 1989 True 5.0 Mustang coupe Super white with gray stripes...all Lights,turn signals,Hazards lights even the ashtray door and electric mirrors work,windshield wipers works...But the 5" extended cowl hood eliminate the wipers,
Interior is in very good shape.gray carpet,gray and black tweed seats,White face instrument White face Oil and water gauges in heat vent gauge pod
Engine is a Ron Anderson Long rod 306 cib that was refreshen by Alvin Brewer(Farmer boy Performance) It has The real GT-40 tubular upper and lower intakes (red) 24 lbs injectors,75 mm Throttle body with spacer delete,C&L 73 mm Mass air with calibrated tube,Cold Air and filter,NOS manifold plate, Pro Comp aluminum Heads with 205/160 valves these heads are setup for a solid Lift roller which is what's in it 610/610 cam motion cam with 1.7 roller rockers,Flat top eagle rods and pistons,(Stock crank),Stud girdle,Canton deep oil pan,BBK equal length headers,H-pipe,Flow master,T-5 Trans,pro 5.0 short throw Shifter,center force clutch,UPR adjustable clutch cable. (stock drive shaft) 255 liter fuel pump,MSD Digital 6 box,MSD Billet EFI Distributor
Front Suspension D&D tubular k-member,tubular A-arms,competition eng struts,UPR coil over kit,Flaming river rack&pinion and steering shaft power kit,UPR camber caster Plates,(stock brakes)
Rear Suspension is pretty much all stock other then UPR Coil over kit for mustang.The kit is for lakewoods but I modified the stock shock to work with them,stock axles and unit but all in good shape 4.10 gears,Subframe connectors Battery located in the truck
Wheels and tires =front 15x3-165/80/15 Rear-15x8-275/50/15 M/T drag radials...pvt message me or email me at [email protected] let me know what you got....Thanks
Moved to Want to Trade forum.
If you come up with an asking price, send me a private message and I'll relocate it.
Also... Please list item location (city/state) per forum guidelines.
Thanks,
Noobz
