Mild streeter just to cruise ?
Tfs170 twisted wedge or afr165
I’d skip the e cam . Go with an Anderson grind or even a Tfs stage 1 . Depending on your budget having someone do a custom grind like Freezy isn’t much more money esp for a cast core cam .
Converter is really going to depend on the cam. You want it streetable but to be peppy and compliment your upgrades .
I’d throw gears in it too . 3:73 I think would be perfect honestly .
Sub frames , alum drive shaft and you’d have a fun car to run around in .
As far as fuel . A 190lph pump or if you wanted to over kill a 255 would work . For that power 19lb injectors would cut it I’d just do the sn95 MAF Upgrade or I am a big fan of the pro m stuff.
