1989 mass flow or DA1 ?????
serpent00
HI THERE I HAVE A 1989 LX 5.0 I HAVE A DA1 Speed Density Engine Computer ?? WAS 1989 MASS FLOW SO WAS IT CHANGE !!! I HAVE A HOOK UP FOR A MASS FLOW UNDER THE HOOD WHEN I GOT THE CAR THERE WAS JUST A COLD AIR INTAKE OR SHOULD I JUST TRY TO GET A MASS FLOW AND PLUG IT IN AND see what happens ??? THANKS
All 89 5.0 Mustangs came with Mass Air from the factory. They used an A9L for a 5 speed and an A9P for automatic. I think the California cars had an A9S. All of these are Mass Air computers. If you have some other computer, someone has altered the car.
thanks... should i change it or keep it the way it is whats the better way and sorry i'm in the wrong part of the forum :doh:
depends on what you want to do.
Speed Density = exact specifications(doesn't like altitude changes very much)
Mass-Air = Tolerates Changes in almost everything.
If your good with a speed density setup in terms of programming, then go for it, definitely good for specifics. But for the normal bolt on and go scene, Mass-Air is the best IMHO for the benefit of plug and play compatibility.
