1990 5.0 Won't Start
af4cj
Drove the car, tuned it off came back and it wouldn't start. I listened closely and no fuel pump running. Got it home put in a fuel pump, fuel pump still won't run. After researching the problem, the computer is not grounding the relay. I can ground it at the ecc connection under the hood, the fuel pump will then come on, good fuel pressure. Car still will not start.. Spark plugs are firing,the injectors have voltage. Do I need to replace the computer??
AF4CJ
