Electrical 1990 GT - Weird Electrical Issue
90foxbody00
21
Washington
Ok so for about a week now I've been getting this odd electrical issue with my 90 GT only when it's raining (I live in Seattle so pretty much everyday that ends with Y). It started last Friday when I was heading home from work, the radio will cut out for about half a second and the wipers will stop for between 30 seconds to a minute and a half, and it will sometimes cause the car to shudder when the radio cuts out. I checked and cleaned the main ground and the 2 grounds on the driver's side fender apron and that didn't really do anything. It seems like a connector issue but I'm not sure exactly which one could be the culprit. Any help would be great
So is your solution going to be to not drive in the rain?
you have to start somewhere and I gave you a starting point. These cars are not modern sealed capsules, they are old and problematic when it comes to daily operations.
without hands on diagnostic ability I can only offer best guess answers.
Yeah that wasn't going to be my solution as I said that was the reason my initial guess was an issue with one of the connectors.
Recall on Ford Ignition switches:
Revised 7-June-2014 to add Torx bit picture and source. Also added replacement ignition switch wiring pigtail picture, part numbers and sources.
Some of the symptoms of ignition switch problems are things that don’t work or are intermittent like radio, turn signals, wipers or heater.
There was a FREE recall on Ford ignition switches. They overheat and sometimes catch fire. That burns up the steering column and sometimes the car interior. Since this is very old information, you may not be able to get the switch replaced for free anymore. The auto parts stores sell the switches for $13-$15.
While you are working on the switch, check the wiring and connector closely. A replacement connector with new wiring pigtails is available from most auto parts stores
AutoZone and Advanced Auto Parts have the same Part Number: 434 - may have to order, not always in stock
Advanced Auto Parts alternate part number: PT5534
Saleen0679 was nice enough to dig this up for us awhile back: How to replace ignition switch on 1979-1993 Mustangs.
http://www.mustangandfords.com/how-to/engine/5657/
Torx bit set from Advance Auto Parts
Autocraft torx bit set – have small hole in tip for tamper proof screws.
Part No. AC571/W1386 Cost approx. $12 +tax
Diagrams courtesy of Tmoss & Stang&2birds
Ignition switch wiring
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
First, i am not an expert by any means, but I would look at Jrichker's solution - when my mustang was new (3 months old) I had almost the same identical issue you described (my headlights also went out - interesting story with that, I wont go into it, but it near got me killed.
