- Nov 17, 2005
- 9
- 1
- 13
Hello All
It has been a while. Haven't played with one of these cars in over a decade.
I have just picked up a 1990 Mustang GT from a friend who had it sitting in his driveway for the past decade. ( I couldn't let her die in the driveway)
The car has approximately 42k on it.
It used to run without any issues before it sat.
After a fresh battery installed she barely started but was not running right. Barely idling and would stall when you passed approximately 1/4 throttle.
I have put in the following parts:
New Cap
New Rotor
New Plugs
New Fuel Filter
Fresh Fuel
After all parts installed same hard start bad idle and stalls when you get her started when you pass 1/4 throttle.
I have tested the TPS, swapped the Mass Air with a known good unit and still have the same results.
Here is the strange part for me
When I unplug the Mass Air she will start run for a few seconds and then sputter and stall.
If I unplug the Mass air and also unplug the Idle Air Control it will start and idle without any issue. No sputtering or smoke.
I have verified the computer ground cable at the battery and the grounding strap behind the engine.
I am running out of idea for testing. I do not want to just start throwing parts at it and see what sticks.
If anyone can offer any guidance on this it would be greatly appreciated.
New Cap
New Rotor
New Plugs
New Fuel Filter
Fresh Fuel
