1990 Hatch, White w/ Black int.
White93LX
26
Asking $4,500k OBO. Need this car gone. I don't drive it and I'm looking to get something else. Any questions, call me anytime. 336-301-0911
Odometter redaing 56k....guessing 156k. Couldn't tell it by looking at the car though.
E-Cam
New motorsport lifters
Cloyes double roller timing set
SN-95 SVO Motorsport intake, ported and gasket matched
70mm TB, 70mm C&L cold air and MAF calibrated for 24lbs injectors
Smog pump delete
Flowtech 1-5/8 headers
O/R H-pipe
2-1/2 inch Dynomax bulletts with dumps
Proform electric fan with adjustable thermostat
New radiator, thermostat, water pump
New head gaskets on both sides
Lowered about 2 inches all the way around and sitting on Welds,
15x8 on the rear and 15x6 in the front
B&M shift kit, 2200 stall, 3.73 gear.
Have a primered 3 inch cowl hood already drilled for hood pins and the hood pins that will be included with the car as well.
Could be some stuff I missed. If you have something, let me know.
The interior is a 9.9 out of a 10, and the body is a 7 out of 10. It is an original 5.0 car with with a built aod. Tranny has less than 1,000 mils on it, and all the mods have less than 3k miles on them.
Has small drip from front cover at the oil pan, never got it sealed 100% Leaves a spot about the size of a dime.
Needs 2 new door lock acuators, neither door will lock.
Also, has EGR delete, so check engine light is on.
