1990 Lx 5.0 Holley Systemax Ll Runs Horrible
Little49
ive had ny 90 fox body for 4 years now, bought it with the systemax setup on a stock bottom end, last year I had the block done, bored .30 over Rods, pistons, crank, blueprint balance, heads rebuilt, has 1.6 scorpion rockers, msd 6al, 70 lb injectors that were in it when I bought the car with the walbro 255 in tank, I built this whole motor in hopes of turbocharging it this year and I just cant get this car to run worth of anything, been pulling my hair out with it and I am ready to list it for sale, have all kinds of dough into this thing like everyone else on here and I cannot diag for the life of me, I live in NH and don't know anyone that could help or begin to help me, all I know is its always had one of the three vacuum lines open on the back of the upper intake and when I plug it she starts surging and dies, but when open like it shouldn't be the car runs better? any help is more than appreciative at this point. thank you,
I would try pulling the codes first and see what is going on. My first shot in the dark would involve the 70lb injectors. Those are huge for your motor, which may be why it idles a little better with unmetered air entering the engine. It may be helping to correct the AFR.
Joe
okay joe thank you, how do I go about pulling the codes? and there is no check engine light present, ive just been told numerous ways to do it and haven't really understood how?
What kind of MAF do you have on this engine? Does it match the injectors? Do you have any kind of custom dyno tune?
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Did you build this or buy it from someone else?
The stock MAF will not work properly with anything but the stock 19lb. injectors without a custom dyno tune & chip.
I figured that, I made an appointment with a dyno shop I found somewhat local to me, the guy specializes in these things and I've heard good things so I'll give that a go and see what he can come up with
IMO, pull the chip completely then switch to a pro m calibrated for 30's and go from there.
It would be insane to take a hci intake car with 30lb injectors and a stock meter for a dyno tune. Not sure where a stock meter pegs, but I bet it's less than what you are putting out and there is no tuning that can fix that. Tuning the wrong parts is like throwing money in the garbage.
Or better yet, get some 24's and a 24lb pro m.
You have to have a really potent setup on a 302 to necessitate 30's.
HCI setups run just fine when you get the right meter and injectors.
