1990 LX dies and will not restart when warm!
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Ok guys this is really wierd. 1990 lx 5.0 5 spd. When the car has been sitting and is cold it will start and run fine for 5 to 6 miles, once warm the engine dies and will not restart. Once the car is cool again it will start and run fine again till warm. Engine is only about 500 miles old and compression is great, no head gasket problems. I'm leaning towards electrical issues but what would shut the motor down like this once warm? Just looking for ideas on what to check out. I started with the alt. power wire which was in very poor shape and melted in many spots due to someone using speaker wire to wire the 130 amp alt. I havent gotten to check to see if rewiring this has helped yet or not. So until then just throw out some ideas! Thanks!:SNSign:
When it won't start, it'd be nice to know if it was missing spark, fuel pressure, etc. Pulling codes is also a good idea.
Otherwise, we're going to be taking huge guesses.
Good luck.
89lxcoupe said:
i'm guessing fuel pump getting hot or the tfi module is getting hot and loosing spark, i've had my car miss and i've also had my car die when the module went !
I Agree. My 88 Notch would run fine when first started. It would run fine till shut off. If I tried to restart the engine (like after getting gas) the car would not start. I had spark but no fuel pump. I tracked the problem down to a faulty fuel pump.
Good Luck
I had the same problem. While I was driving and stop for gas wouldnt fire back up. Did it to me 3 times in one day. I let it sit over night and then worked great for a couple weeks give or take and now it wont stay running for more than a few seconds. However I believe my problem is my computer got shorted out. I have my new A9L and as soon as I get it in i will let you know if that was it.
Can you hear your fuel pump prime when you turn the key? There is a fuel pump test connector on the Self Test connector. Ground it and then turn your ignistion on and go to the back of the car. You should be able to hear it pumping. Do a search for trouble pulling codes and look for jrichker post. It will be in there.
GOOD LUCK
ive had the same problem went through many relays and starters and ground wire tfi module and finally i just got used to popping the hood and jumping the relay to start after warm smtms it does it sometimes it dont
sjhm9102 said:
ididnt know 5.0s had a crankshaft sensor ?
That's because they don't. Your symptoms point to a faulty TFI or PIP/stator. Both tend to go bad as they age and both can cause these very symptoms. If you have fuel, but no spark, it points to the TFI. If you have no fuel or spark, it points to the PIP. If you loosen your distributor hold down and rotate the distributor, do you hear your fuel pump prime? The PIP signal tells the computer the engine is running when the distributor is turning, which in turn activates the fuel pump.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 18-Oct-2006 to include TFI fault during crank/run cycle
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
donsbad68 said:
Update! New alt. wiring, new distributor, new Tfi module. Problem still there. What do you think check next? There are no codes. Fuel pump? coil?
When the car failed, what did your testing show? Jrichker's list 'is what should be checked next'. That's going to be the easiest way to figure out the issue, and do so without replacing random parts.
Good luck.
Fix your hot cranking problems first and the other problems may go away on their own.
Notice the section on using a voltmeter to check the quality of connections. I would read it very carefully and test all the starter power & ground wiring.
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
This happened to me too i would drive it for like 3-5 miles and it would leave me on the side of the road....this happened twice.
I have an MSD dizzy so it doesn't matter what kind you have it will happen to everyone in due time. If you want to buy a new dizzy it will fix the problem but if you want to spend less that $20.00 go to auto zone with the dizzy taken off and they can test the TFI module for you and if it reads ok its the pick-up coil PN#F122. I've had to replace mine when this happened and the car has been running great every since. I called MSD because i thought they made one but they use a stock piece so i just got it at the zone.
You will have to remove the holding pin and gear to get this done. I should have taken picks but i just wanted to get her running again..
http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performMoreDetail&Parameters=TRUE%7C%7EPick-Up+Coil%7C%7ENONE%7C%7EWELLS%7C%7ENONE%7C%7EFALSE%7C%7EFALSE%7C%7E184572%7C%7E3516%7C%7EF122%7C%7EThe+distributor+must+be+removed+to+install++++++++++++%0Apick+up+coils.%7C%7E%2417.99%7C%7EFord%7C%7EMustang%7C%7E1990%7C%7ENONE%7C%7E0.1%7C%7ENONE%7C%7EB
Good Luck
Benny
