1990 Mustang Gt ( Massacshuetts )
1990 Mustang GT 5 spd, clean title, rebuilt rear end 4.10 gears, block bored .030 over, new cam bearings, rod bearings, main bearings etc, new oil pump, crower cam .222 / .228 duration - .496 /.512 lift, speed pro pistons, ground crank, stock ported / polished heads, trick flow valve springs, cobra upper and lower intake with spacer, bbk 70mm throttle body, pro-m mass air meter, 42lb injectors, adjustable fuel pressure regulator, brand new 255lph fuel pump, fuel sending unit, alternator, starter, power steering pump, water pump, clutch fan, mallory distributor brand new cap & rotor, hooker headers, off road h-pipe, flowmaters, pro 5.0 shifter, weld draglites with newer tires. new rebuilt motor has low oil pressure issues, just parts alone are worth asking price. will take motor out if someone wants it without. $4,500 complete $4,000 without motor.. email for easiet and quickest responce. [email protected]
