Expired 1992 Fox Body Mustang Lx 5.0 Notch Back 5 Speed With Many Mods
michael marks
1992 LX original 5.0 5 speed 87k miles trick flow top end kit aluminum heads upper and lower intake and cam bbk shorty headers off road h pipe 40 series flowmasters a/c delete smog delete koni adjustable shocks and lowering springs car has been lower one and a half inches, zoom clutch ford racing aluminum drive shaft stiffer sway bars front and rear, 3.73 gears in the rear, new inner and outer tie rod ends new ball joints short throw shifter clutch quadrant firewall adjuster, car is originally from north Carolina. mods have less then 3000 miles tires are two years old runs and drives good sounds great fun to drive, car is located in Janesville Wisconsin call for more info 608-359-4757
1992 LX original 5.0 5 speed 87k miles trick flow top end kit aluminum heads upper and lower intake and cam bbk shorty headers off road h pipe 40 series flowmasters a/c delete smog delete koni adjustable shocks and lowering springs car has been lower one and a half inches, zoom clutch ford racing aluminum drive shaft stiffer sway bars front and rear, 3.73 gears in the rear, new inner and outer tie rod ends new ball joints short throw shifter clutch quadrant firewall adjuster, car is originally from north Carolina. mods have less then 3000 miles tires are two years old runs and drives good sounds great fun to drive, car is located in Janesville Wisconsin call for more info 608-359-4757 $5500
