Asking $8500.00
The Good:
Professionally built 331 Stroker by Ed Thomas Performance Engines 9:1 compression (engine built 09/11 and installed 04/12 receipts on hand)
Approx. 1000 miles on new motor
Tuned and dyno’d by Performance Evolution 325.68 HP/351.58 Torque at the wheels (Dyno sheet on hand)
Trick Flow Street Heat Upper and Lower Intake
BBK Headers
BBK 70mm throttle body
MSD 6AL Ignition
MSD Distributor
New 95 Amp polished PA Performance Alternator
Polished engine pulleys
Mishimoto Aluminum Radiator and electric fan
New Water pump
New Power steering pump
Anderson Motorsports Power Pipe
24lb injectors
1.7 roller rockers
ported and polished cast GT40 heads
Walbro 255 fuel pump
New Poly motor/trans mounts
New Spec stage 2 clutch
Steeda Firewall clutch adjuster
Pro 5.0 shifter
New NAPA starter
Trans was recently drained and filled with Royal Purple Synthetic
3.73 rear
New Tokico Blue shocks
Lowering springs
New Corbeau leather front seats
New Vinyl recovered matching rear seats
New Carpet(mass back molded)
Magnaflow exhaust with high flow cats
Prosport water temp/oil pressure/volt gauges installed in dash but not yet connected to sensors.
Factory A/C compressor in possession but not installed on car
Rear seat delete in box, never used
The Bad:
Needs fresh paint
Door panels could use a refreshening
Rear window guides need replacing(windows come up a bit crooked
Weather striping needs to be replaced
Convertible top hydraulic cylinder just replaced but needs to be refilled with fluid. Motor works fine but top has to be manually taken up and down right now until job is finished (hasn’t been a priority since I only drive it in fair weather)
Power door locks not functioning-it appears that the switches in the doors just need to be replaced.
Power steering rack has a minor drip
I’m sure that there is something I’m missing. Car runs great just trying to downsize a bit
Car has not been involved in any crashes that I am aware of and I do not race it. Car is garage kept and not driven in bad weather. I have many receipts for the items listed above and can email additional pics or a vid of running car. email to [email protected] Vehicle is located in Middletown, Delaware
The Good:
BBK Headers
MSD 6AL Ignition
MSD Distributor
New Water pump
24lb injectors
1.7 roller rockers
Pro 5.0 shifter
New NAPA starter
3.73 rear
Lowering springs
The Bad:
Needs fresh paint
