1992 mustang gt build thread (1bad67sbf)
For cleaning gunk off windows i use razor blade+windex...
what i have going on is someone put blue tint on the sunroof and it is now purple so i want it off but i have removed tint film from my old truck and it was a disaster to get the glue off and i tried tint film remover, windex, i even put carb cleaner on a rag (that worked best so far but still not great). their has to be an easy way to do it.
well i got the sunroof done and started thinking about the engine some, so i have a A9L ecu and a non ho motor so i need to get a cam to fix this. this is what i have now and what i need to know is can i make this a roller setup with this comp cams kit? then i can get a set of roller lifters and a mild or stock ho cam
thats what my issue is i have a a9l ecu with a HO firing order so i need to put a cam in that will work with the a9l. all 351w cams i looked at said non computer cam so i want to put a HO roller cam in it. i just talked to my buddy and he has a engine im going to buy from him and it is a roller setup so i wanted to swap the parts to this block until i get the engine work done on the true roller block. it also has an edelbrock performer intake on it i could use.
The absolute easiest way and less obtrusive is to get a steam cleaner from good ole wal mart. 20 bucks and you're done. Read any tint forum, they'll tell ya the same
ok, well the cam should work fine so i need to pick what cam i should get from the two below, any comments would be helpfull, keep in mind this engine will most likley end up in my 84 f150 4X4 when i get my roller motor done so i want to get a cam with a good bottom end but still pull ok up top.
https://www.lunatipower.com/Product.aspx?id=2513&gid=309
or
https://www.lunatipower.com/Product.aspx?id=2514&gid=309
any other flat tappet cam kits in this price range are also an option if its better but i do like Lunati.
any chance the small one will be ok with stock springs?
You can turn the engine upside down and drill and tap the valley for the spider and use the spider and lifter guides from a roller 302 then use roller lifters and any roller cam for a 302 ho efi
Before you do it you need to check the lifter bores and see if they are the same as a 302 roller block. If they are then you can do the swap by drilling and tapping. If not then you will want to use link bar rollers or a flat tappet.
I just read that "EVERY SINGLE 302 from 1985 and up is a roller block regardless of what cam ford put in it roller or flat tappet" If this is true than you can simply drill and tap the valley and use the stock parts from a ho engine.
