1993 Cobra -- wheel studs
mustangcobra93
928
I just ordered some 31 spline moser axles. I got the standard length studs because I figured 3" studs would not fit under my center caps. How far would 3" studs extend past my center cap?
probably an inch or less..
I personally would have gone the same route you went... question.. did you remember to get the 93 Cobra length axles? they are wider than the GTs... same as SN95 width..
I went through the same decision with my car.. kept stock length wheel studs b/c I didnt care for how exposed longer studs would look on my wheels.. that being said.. I just have to select a wheel like the center line telstars or something.. they use std conical seat lugs.. therefore no need for longer studs.
plus my DRs are on 95GT wheels.. and those are stock lug wheels as well.
hope that helps
Adam
