Interior and Upholstery 1993 Ford Must GT Convertible | Radio Trim Bezel | Gauge Bezel
FGutier105
9
Vero Beach
I'm looking for the radio trim bezel without the 4 holes they usually make when the replace the original radio for an aftermarket. Is part of the center console but I believe is interchangeable as it has 4 screws in the back of it. I'm also looking for the gauge bezel, it seems at some point they installed an aftermarket alarm and they drilled a hole near the light dimmer. Thank you.
So you guys see what I am referring to. Thanks a million.
I had the same problem and filled the holes with JP Weld plastic filler then sanded and painted with SEM Landau Black which is a perfect interior match for our cars. It came out very nice. Nothing noticeable unless you know what to look for, stare at it, and even then it still looks fine.
You may want to try this and if your not happy you can always continue to search for the parts to swap out.
Would you be open to fix it for me if I detach it and mail it out to you? For a fee of course.
I wish you lived close to me. We would do it together. It Wouldn’t be worth it for you to mail it out. Give it a shot, it’s easy otherwise just change the parts like you originally were going to do. If you were a ride away I would have done it but it’s not worth you sending your parts out.
Reactions: FGutier105
Thank you. I've come to realized that I will have to change the entire center console as that particular part does not detach from it.
Couple years back I fixed the holes in my center console like @Mustang5L5 described.
Repaired the holes with plastic filler. I used LMR black interior paint (I think there are cheaper options now) and the SEM texture paint to match the factory texture as best I could. The console trim has the Ford wavy texture which the SEM wont do.
I tried the stamp method on another trim piece with no luck
View: https://www.youtube.com/watch?v=85FYd9TjLSI
Filler: Amazon product ASIN B0076LAVFKView: https://www.amazon.com/gp/product/B0076LAVFK/
SEM Texture: Amazon product ASIN B000PL074SView: https://www.amazon.com/SEM-39853-Texture-Coating-Aerosol/dp/B000PL074S
Black paint: https://lmr.com/item/MET-FV33/90-95-Mustang-Black-Vinyl-Interior-Paint
I am pleased with the results.
Thank you so much.
Reactions: FortySix&2
