- Sep 3, 2015
- 1
- 0
- 1
You are looking at a 1993 mustang lx
street legal, very clean and no accidents. Car has many upgraded performance parts posi rear with 355 gears, aluminum drive shaft, new king cobra clutch , Tremec t-5 tranny. Motor is a 306 with forged pistons, has trickflow cam, upper lower intake and aluminum trick flow heads with the 1.72 roller rockers. Matched with cold air intake 75mm mass air and thirty pound injectors. CSR Products, MSD, Flexalite..too any upgrades. The car sounds great with the long tube headers, x-pipe, and dump mufflers. this mustang is a head turner and always garage kept. the new head lights and custom flame paint job really sets it off. Also has weld racing rims with all new tires upgraded Hotckis suspension, it really drives like a new car. if you have any questions please give me a call 561-212-9944 , BOCA RATON, FL $11,000 O.B.O
355 gears
king cobra clutch
bbk adjustable quaderate
subframe connecters
caster camber plates
poly bushing suspension
3 core aluminum radiator
electric cooling fan
aluminum under drive pulleys
cold air intake
75 mm throttle body
75mm mass air
30 lbs injectors
high pressure fuel pump
trick flow upper and lower intake
aluminum heads
msd ignition box
long tube headers/flowmaster/dump pipes
weld racing rims
cervini fiberglass hood
new ac lines
one piece headlights
rockford fosgate speakers
auto meter gauges
new door lock acuators
white face instrument cluster
hurst shifter
msd cap/rotor/wires
im sure im missing some of it lol
street legal, very clean and no accidents. Car has many upgraded performance parts posi rear with 355 gears, aluminum drive shaft, new king cobra clutch , Tremec t-5 tranny. Motor is a 306 with forged pistons, has trickflow cam, upper lower intake and aluminum trick flow heads with the 1.72 roller rockers. Matched with cold air intake 75mm mass air and thirty pound injectors. CSR Products, MSD, Flexalite..too any upgrades. The car sounds great with the long tube headers, x-pipe, and dump mufflers. this mustang is a head turner and always garage kept. the new head lights and custom flame paint job really sets it off. Also has weld racing rims with all new tires upgraded Hotckis suspension, it really drives like a new car. if you have any questions please give me a call 561-212-9944 , BOCA RATON, FL $11,000 O.B.O355 gears
king cobra clutch
subframe connecters
cold air intake
75 mm throttle body
75mm mass air
30 lbs injectors
aluminum heads
msd ignition box
weld racing rims
new ac lines
auto meter gauges
hurst shifter
msd cap/rotor/wires
