1993 Radiators Rebuildable?
  • Thread starter Thread starter All Stock93
  • Start date Start date May 5, 2017
All Stock93
5 Year Member
Apr 16, 2016
349
542
123
May 5, 2017
  • May 5, 2017
hi all,
I am searching for a stock 93 Radiator to replace the aftermarket aluminum radiator my car currently has. I was wondering, since I don't have a factory radiator to look at, if they are able to be rebuilt or are they plastic throw away's?
Also, is there any difference between 5 speed and auto cars or are the units the same?
Thanks
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
May 5, 2017
  • May 5, 2017
First why would you want a stock one? Aluminum is way better for heat dissipation.
Second: The oem radiator isn't worth rebuilding. Its not cost effective when there are tons of aftermarket oem style replacements. I bought one at Advance Auto last time I needed one. Quality was good fit was good. Price was reasonable.
All Stock93
5 Year Member
Apr 16, 2016
349
542
123
May 5, 2017
  • May 5, 2017
Thanks,
I want a stock one because that's what belongs in the car. This car gets used on sunny days only. Never raced, all original as Ford built it. Extra cooling isn't a priority, 100% original is. I just want to make sure it isn't plastic before I buy one
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 5, 2017
  • May 5, 2017
Well order one from Ford Racing. These cars were under cooled and under alternatored (word?) from the factory.
Reactions: Davedacarpainter
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
May 5, 2017
  • May 5, 2017
I don't remember if the stock one has plastic tanks, there really is no problem with plastic tanks, the car manufacturers are all using them now.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 5, 2017
  • May 5, 2017
The cost to rebuild/recore a copper/brass radiator is easily equal to the cost of a new aluminum HD 2 core from Rock Auto parts.
Unless you are doing a restore to original condition rebuild, the rock auto radiator is the way to go. P/N is OSC 138 - Heavy Duty 2 core aluminum, equal to 3 core. All aluminum, welded tanks,
See http://www.rockauto.com/en/moreinfo.php?pk=3757926&cc=1134076&jsn=460 cost is $106 + shipping.
Reactions: General karthief
All Stock93
5 Year Member
Apr 16, 2016
349
542
123
May 5, 2017
  • May 5, 2017
Guys, Thanks for the help but I don't need an aftermarket unit. I already have a perfect aluminum radiator that is only 2 years old but I'm working towards MCA unrestored class shows. I need a correct FOMOCO radiator from 1993
I have found two suitable radiators but I want to make sure they can be rebuilt if necessary. I know most manufacturers are using plastic tanks these days but I was under the impression that they are throw away units that cant be rebuilt due to the plastic tanks.
Also still wondering if 5 speed and auto use the same unit or if I need to find a 5 speed specific unit
Thanks again
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
May 5, 2017
  • May 5, 2017
AOD units will have the provision for the trans cooler in the driver's side tank on the radiator. Do not know if the 5-spd units had this.
As for rebuilding them, not sure. Been some time since I've seen a stock fox radiator. I want to say they are NOT plasti tanks on the sides though.
Reactions: All Stock93
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
May 5, 2017
  • May 5, 2017
My stock radiator had plastic side tanks.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
May 5, 2017
#10
  • May 5, 2017
  • #10
My stock radiator was brass and copper. It was rebuildable and my radiator did have an internal trans cooler. The car was a 5 speed. The radiator was thicker than the replacement aftermarket one. I do know for a fact that 89 was rebuildable...not so sure about 93.
Have you checked over on 4eyedpride forum ?...there are a lot of purists over there.
I think what you're doing is pretty cool. Nothing wrong with an all stock 93 fox. Really won't be a n y t h i n g wrong with its value in another 10 - 20 year either.
I'll research the great interweb and report back if I find any new info for you.
All Stock93
5 Year Member
Apr 16, 2016
349
542
123
May 5, 2017
#11
  • May 5, 2017
  • #11
Thanks for the help guys. I appreciate any info.
90sickfox said:
My stock radiator was brass and copper. It was the uikdable and my radiator did have an internal trans cooler. The car was a 5 speed. The radiator was thicker than the replacement aftermarket one. I do know for a fact that 89 was rebuildable...not so sure about 93.
I think what you're doing is pretty cool. Nothing wrong with an all stock 93 fox. Really won't be a n y t h I n g wrong with its value in another 10 - 20 year either.
Thanks for researching this. I have a call in to the local radiator shop so I will also check back when I have info
All Stock93
5 Year Member
Apr 16, 2016
349
542
123
May 5, 2017
#12
  • May 5, 2017
  • #12
Local radiator shop says his book shows they can be rebuilt. Will cost about $275
krazedstang
670
278
104
Streamwood
May 5, 2017
#13
  • May 5, 2017
  • #13
I should be pulling the stock radiator out of my 93 convertible in a few weeks, nothing wrong with it I'm just doing an engine swap so it'll have to come out anyways, I'd be interested in possibly swapping radiators with you.
All Stock93
5 Year Member
Apr 16, 2016
349
542
123
May 5, 2017
#14
  • May 5, 2017
  • #14
I'm watching an ebay auction right now, ends in 5 days. If I don't win I may be good with that offer, thanks
Reactions: krazedstang
90sickfox
Mar 2, 2015
6,953
5,831
213
May 5, 2017
#15
  • May 5, 2017
  • #15
I'd like to see some before and after pics of the radiator when its rebuilt. Would be nice to find out if there were any stamping marks or paint marks on them and if they could be duplicated.
Who Is Up To Date On DCC Fan Controllers?
  • BoostedRed89gt
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2026
revhead347
For Sale 1993 Mustang SVT Cobra - Black - 5 Speed - 88k Miles - Single Owner
  • Buddy Jake
  • Jun 16, 2026
Fox Body Mustangs For Sale (1979-93) Jun 20, 2026
Habu135
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
