1995 GT Saleen clone *Low miles*
94_5.0
337
Jacksonville, NC
Color: Screaming Yellow w/ Black interior
Miles: Body 71,000 / Engine 5,000
5-Speed Manual w/ king cobra clutch
Anderson Motorsports PMS fuel management system.
Push button Start.
Steeda clutch cable and adjustable quadrant.
Fully built motor with DSS 306 stroker kit low compression setup made for a turbo or supercharger.
Trick Flow Twisted Wedge heads (fresh valve job)
Trick Flow Stage 1 cam
1.6 roller rockers.
Saleen/Holley long runner intake upper and lower manifold.
75mm throttle body, and MAF tuned for 24 lb/hr injectors (with injectors).
Full 76mm PVC Cold Air Intake with a reusable filter (not shown in the pictures).
Full 2.5 inch exhaust system (BBK equal length shorty headers, H-pipe, 2-Chamber Flow masters and Borla tail pipes). Large 3-row Radiator with polished Shelby overflow tank.
Trunk mounted battery.
Full Saleen S-351 Body (Heat extractor hood) with all of the metal screens.
Saleen 18 inch black powder coated rims with 1/2 inch wheel spacers.
Saleen 200 mph white face speedometer.
Saleen satin aluminum sill plates
Full suspension setup (welded in full length sub frame connectors, rear upper and lower control arms, 1 inch front and rear sway bars, and drop springs).
3.73 Rear end gears.
PBR 12 inch front breaks with cross drilled and slotted rotors.
Upgraded 11 inch rear brakes.
Custom built 10 inch sub box with amp (P3 Fosgate sub and Alpine mono block amp).
FR500 Leather wrapped steering wheel.
Export folding mirrors and tail lights (with amber turn signal, not shown in the pictures).
Leather rear seats.
After market Panasonic CD/deck with MP-3 jack.
MA audio front speakers.
Autopage 2-way Alarm system w/ LCD remote.
The bad:
The front drivers seat has a good size tear in it.
The speedo is off from the gears.
I think that is it.
Looking to get around 10500.00 for her.
These pics are a little old, if you want pictures of specific things just let me know.
